[petsc-users] MatConvert using mpi block aij matrix
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 22 13:09:23 CDT 2010
   Same basic problem. It is using a slow converter that does not do preallocation.
   Since the writer is now available for you, you should just switch to petsc-dev and you won't need this.
   Barry
On Sep 22, 2010, at 12:45 PM, Gaetan Kenway wrote:
> Hello
> I'm still trying to write out my mpiblockaij matrix. I see the development version now supports the baij format writing, but I was just trying to do the matconvert fix to write out the matrix. The code I'm trying to run to convert the matrix is:
> call MatConvert(drdwt,'mpiaij',MAT_INITIAL_MATRIX,drdwt_copy,ierr)
> drdwt was created using:
> call MatCreateMPIBAIJ(SUMB_PETSC_COMM_WORLD, nw, nDimW, nDimW, ETSC_DETERMINE, PETSC_DETERMINE, &
>                              nzDiagonalW, nnzDiagonal, nzOffDiag, nnzOffDiag,  dRdWT, PETScIerr)
> However, the code hangs on the conversion. The drdwt is assembled and drdwt_copy matrix has nothing done to it at this point.
> Any suggestions other than to build the dev version?
> Gaetan
