[petsc-users] Trying to compile PETSC in cygwin
    Randall Mackie
    rlmackie862 at gmail.com
    Fri Sep  3 17:53:14 CDT 2010
I figured it out myself - I had the wrong option below, should have been
--with-clanguage=cxx
although I'm not sure why it didn't work with just gcc.
Randy M.
On Fri, Sep 3, 2010 at 3:20 PM, Randall Mackie <rlmackie862 at gmail.com>wrote:
> I'm trying to compile a uniprocessor version of my PETSc code on Windows
> under cygwin.
> I just downloaded and installed cygwin plus gcc, g++, and gfortran, and
> lapack.
> Whenever I run configure, I get the following error message:
> $ ./configure PETSC_ARCH=windows-gfortran-serial --with-fortran
> --with-fortran-kernels=1 --with-scalar-type=co
> mplex --with-debugging=0 --with-mpi=0 --with-c-language=cxx
>              Configuring PETSc to compile on your
> system
> WARNING! Compiling PETSc with no debugging, this
> should                                                              only be
> done for timing and production runs. All development
> should                                            be done when configured
> using --with-debugging=1
> TESTING: configureScalarType from
> PETSc.utilities.scalarTypes(config/PETSc/utilities/scalarTypes.py:36)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> C Compiler provided doest not support C99 complex
> I've even tried adding the option --CFLAGS='-std=c99', but I get the same
> error message.
> Anybody have any suggestions for how to get past this?
> Thanks,
> Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100903/eaa76f65/attachment.htm>
