[petsc-users] Trying to compile PETSC in cygwin
Randall Mackie rlmackie862 at gmail.com
Fri Sep 3 17:20:53 CDT 2010
I'm trying to compile a uniprocessor version of my PETSc code on Windows
under cygwin.
I just downloaded and installed cygwin plus gcc, g++, and gfortran, and
lapack.
Whenever I run configure, I get the following error message:
$ ./configure PETSC_ARCH=windows-gfortran-serial --with-fortran
--with-fortran-kernels=1 --with-scalar-type=co
mplex --with-debugging=0 --with-mpi=0 --with-c-language=cxx
             Configuring PETSc to compile on your
system
WARNING! Compiling PETSc with no debugging, this
should                                                              only be
done for timing and production runs. All development
should                                            be done when configured
using --with-debugging=1
TESTING: configureScalarType from
PETSc.utilities.scalarTypes(config/PETSc/utilities/scalarTypes.py:36)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
C Compiler provided doest not support C99 complex
I've even tried adding the option --CFLAGS='-std=c99', but I get the same
error message.
Anybody have any suggestions for how to get past this?
Randy M.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100903/a0251f6b/attachment.htm>
