[petsc-users] TS with inhomogeneous rhs
Chetan Jhurani chetan.jhurani at gmail.com
Thu Nov 18 19:07:28 CST 2010
Thanks Barry and Jed.  TSSetIFunction and TSSetIJacobian from petsc-dev
are working perfectly.
Chetan
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Jed Brown
Sent: Thursday, November 18, 2010 3:49 PM
To: PETSc users list
Subject: Re: [petsc-users] TS with inhomogeneous rhs
On Thu, Nov 18, 2010 at 23:14, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
     M U_t = -K U + f(t)
In addition, how can the code be kept nearly identical to allow different
TS types to be used (EULER, BEULER, TSRUNGE_KUTTA, TSCRANK_NICHOLSON,
etc)?  I'd also like to take possible advantages of M and K being
constants.
As Barry says, we are transitioning to a better API for this.  You can use TSTHETA (theta=0.5 is Crank-Nicolson, theta=1 is Backward Euler) with TSSetIFunction and TSSetIJacobian (see the man pages or read section 6.1.2 of the users manual).  Note that an "explicit" method for your problem above needs to solve with the mass matrix at every time step.  Unless it is very cheap (e.g. block diagonal), then it may not be worth it.  PETSc's explicit methods do not currently support this, but support for that will be added in the next few months.  At present, you would need to do the solve in your RHSFunction.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101118/af13af84/attachment-0001.htm>
