[petsc-users] Compile Errors with ifort 11.1
    Satish Balay
    balay at mcs.anl.gov
    Fri Nov 12 11:34:24 CST 2010
Make sure your compiles have all the flags listed here..
Its best to use petsc makefile formats so that this info is
automatically picked up from the petsc config files. [and not tweak
user makefiles for every install of petsc..]
Satish
On Fri, 12 Nov 2010, Tahar Amari wrote:
> You are right.
> Here is what I got
> timac> make getincludedirs getlinklibs
> -I/Data/Poub1/petsc-3.1-p5/macx/include -I/Data/Poub1/petsc-3.1-p5/include -I/Data/Poub1/petsc-3.1-p5/macx/include
> -L/Data/Poub1/petsc-3.1-p5/macx/lib -L/Data/Poub1/petsc-3.1-p5/macx/lib -L/Data/Poub1/petsc-3.1-p5/macx/lib -lpetsc -L/usr/X11R6/lib -lX11 -L/Data/Poub1/petsc-3.1-p5/macx/lib -lparmetis -lmetis -lflapack -lfblas -L/Data/Poub1/petsc-3.1-p5/macx/lib -L/usr/lib/gcc/i686-apple-darwin10/4.2.1/x86_64 -L/usr/lib/i686-apple-darwin10/4.2.1 -L/opt/intel/Compiler/11.1/088/lib -L/opt/intel/Compiler/11.1/088/Frameworks/mkl/lib/em64t -L/usr/lib/gcc/i686-apple-darwin10/4.2.1 -ldl -lpmpich -lmpich -lSystem -lmpichf90 -lifport -lifcore -limf -lsvml -lipgo -lgcc_s.10.5 -lSystemStubs -lmx -lirc -lpthread -ldl -lpmpich -lmpich -lSystem -ldl
> What does it mean please for me to change in my makefiles ?
> Do you mean that I should remove any link other than -lpetsc ?
> Great thanks
> Tahar
> Le 12 nov. 2010 à 18:26, Satish Balay a écrit :
> > Looks like you are not using PETSc makefiles - and upgrading from
> > older release to petsc-3.1
> > Currently there is only one library for petsc [-lpetsc]
> > Check:
> > cd $PETSC_DIR
> > Satish
> >> Many thanks. This is solved.
> >> Now at link I have the library not found. Any idea ?
> >> -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
> >> ld: library not found for -lpetscsnes
> >> Tahar
> >> Le 12 nov. 2010 à 18:17, Satish Balay a écrit :
> >>> Looks like this is related to the following:
> >>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/31.html
> >>> # petsc.h and petscdef.h are replaced with petscsys.h and petscsysdef.h; while petsc.h now includes ALL PETSc include files.
> >>> Try removing all includes other than 'petsc.h' from your code.
> >>> Satish
> >>>> Hello,
> >>>> While compiling one of my code with ifort , I have the following error pointing
> >>>> towards petscvec.h .
> >>>> Any idea about this posssible kind of error please ? Any option of ifort to use ?
> >>>> Many thanks
> >>>> Tahar
> >>>> ifort -assume byterecl  -I/usr/local/petsc/ -I/usr/local/petsc//include -I/usr/local/petsc//include/finclude -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11 -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -DPETSC_USE_BOPT_g -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c petsc.fpp
> >>>> /usr/local/petsc//include/finclude/petscvec.h(10): error #6418: This name has already been assigned a data type.   [NORM_1]
> >>>>     integer(kind=selected_int_kind(5)) NORM_1
> >>>> T. Amari
> >>>> Centre de Physique Theorique
> >>>> Ecole Polytechnique
> >>>> 91128 Palaiseau Cedex France
> >>>> tel : 33 1 69 33 42 52
> >>>> fax: 33 1 69 33 49 49
> >>>> email: <mailto:amari at cpht.polytechnique.fr>
> >>>> URL : http://www.cpht.polytechnique.fr/cpht/amari
> >> T. Amari
> >> Ecole Polytechnique
> T. Amari
> Ecole Polytechnique
