[petsc-users] Compile Errors with ifort 11.1
    Satish Balay
    balay at mcs.anl.gov
    Fri Nov 12 11:26:30 CST 2010
Looks like you are not using PETSc makefiles - and upgrading from
older release to petsc-3.1
Currently there is only one library for petsc [-lpetsc]
Check:
cd $PETSC_DIR
make getincludedirs getlinklibs
Satish
On Fri, 12 Nov 2010, Tahar Amari wrote:
> Many thanks. This is solved.
> Now at link I have the library not found. Any idea ?
>  -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
> ld: library not found for -lpetscsnes
> Tahar
> Le 12 nov. 2010 à 18:17, Satish Balay a écrit :
> > Looks like this is related to the following:
> > http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/31.html
> > # petsc.h and petscdef.h are replaced with petscsys.h and petscsysdef.h; while petsc.h now includes ALL PETSc include files.
> > Try removing all includes other than 'petsc.h' from your code.
> > Satish
> >> Hello,
> >> While compiling one of my code with ifort , I have the following error pointing
> >> towards petscvec.h .
> >> Any idea about this posssible kind of error please ? Any option of ifort to use ?
> >> Many thanks
> >> Tahar
> >> ifort -assume byterecl  -I/usr/local/petsc/ -I/usr/local/petsc//include -I/usr/local/petsc//include/finclude -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11 -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -DPETSC_USE_BOPT_g -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c petsc.fpp
> >> /usr/local/petsc//include/finclude/petscvec.h(10): error #6418: This name has already been assigned a data type.   [NORM_1]
> >>      integer(kind=selected_int_kind(5)) NORM_1
> >> T. Amari
> >> Centre de Physique Theorique
> >> Ecole Polytechnique
> >> 91128 Palaiseau Cedex France
> >> tel : 33 1 69 33 42 52
> >> fax: 33 1 69 33 49 49
> >> email: <mailto:amari at cpht.polytechnique.fr>
> >> URL : http://www.cpht.polytechnique.fr/cpht/amari
> T. Amari
> Ecole Polytechnique
