[petsc-users] Compile Errors with ifort 11.1
Tahar Amari
amari at cpht.polytechnique.fr
Fri Nov 12 11:23:23 CST 2010
Many thanks. This is solved.
Now at link I have the library not found. Any idea ?
-L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
ld: library not found for -lpetscsnes
Tahar
Le 12 nov. 2010 à 18:17, Satish Balay a écrit :
> Looks like this is related to the following:
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/changes/31.html
> # petsc.h and petscdef.h are replaced with petscsys.h and petscsysdef.h; while petsc.h now includes ALL PETSc include files.
> Try removing all includes other than 'petsc.h' from your code.
> Satish
> On Fri, 12 Nov 2010, Tahar Amari wrote:
>> Hello,
>> While compiling one of my code with ifort , I have the following error pointing
>> towards petscvec.h .
>> Any idea about this posssible kind of error please ? Any option of ifort to use ?
>> Many thanks
>> Tahar
>> ifort -assume byterecl -I/usr/local/petsc/ -I/usr/local/petsc//include -I/usr/local/petsc//include/finclude -I/usr/local/petsc//macx/include -I/usr/X11R6/include/X11 -DPETSC_HAVE_PARMETIS -DPETSC_USE_DEBUG -DPETSC_USE_LOG -DPETSC_USE_BOPT_g -DPETSC_USE_STACK -DPETSC_AVOID_MPIF_H -c petsc.fpp
>> /usr/local/petsc//include/finclude/petscvec.h(10): error #6418: This name has already been assigned a data type. [NORM_1]
>> integer(kind=selected_int_kind(5)) NORM_1
>> T. Amari
>> Centre de Physique Theorique
>> Ecole Polytechnique
>> 91128 Palaiseau Cedex France
>> tel : 33 1 69 33 42 52
>> fax: 33 1 69 33 49 49
>> email: <mailto:amari at cpht.polytechnique.fr>
>> URL : http://www.cpht.polytechnique.fr/cpht/amari
T. Amari
Ecole Polytechnique
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101112/4ae52c69/attachment.htm>
