[petsc-users] Compile Errors in Make files
Satish Balay
balay at mcs.anl.gov
Fri Nov 12 10:39:11 CST 2010
On Fri, 12 Nov 2010, Nunion wrote:
> Initially, I thought that was the case as well. However, I saved some
> output from installation;
Why don't you try the provided suggestion - and say if it worked or -
not?
and if it didn't - furnish further relavent info - like the command
used, errors obtained, makefile used?
And how and where exactly did you set PETSC_ARCH and PETSC_DIR?
BTW: The log you qouted mentiones one way of using PETSC_ARCH and PETSC_DIR with 'make'
> make PETSC_DIR=/home/walker/Desktop/PETSc/LITE/petsc-3.1-p4 PETSC_ARCH=linux-gnu-c-debug all
Satish
> On Fri, Nov 12, 2010 at 10:07 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > You have not set your PETSC_ARCH and PETSC_DIR
> > On Nov 12, 2010, at 9:43 AM, Nunion wrote:
> > > Hello,
> > > I recently started receiving the following error when trying to compile
> > anything...
> > > makefile:16: /conf/variables: No such file or directory
> > > makefile:17: /conf/rules: No such file or directory
> > > makefile:858: /conf/test: No such file or directory
> > > make: *** No rule to make target `/conf/test'. Stop.
> > > The errors seem to be related to one another. I tried to hardcode this
> > path, but the makefile is not picking up the path. I can't recall changing
> > anything major
> > > Thanks!
> > > Mark
