[petsc-users] Compile Errors in Make files
Nunion
m.skates82 at gmail.com
Fri Nov 12 10:26:02 CST 2010
Initially, I thought that was the case as well. However, I saved some
output from installation;
Configuring PETSc to compile on your
system
TESTING: alternateConfigureLibrary from
PETSc.packages.petsc4py(config/PETSc/packages/petsc4py.py:64)
Compilers:
C Compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -g3
Fortran Compiler: mpif90 -g
Linkers:
Static linker: /usr/bin/ar cr
Dynamic linker: mpicc -shared -Wall -Wwrite-strings
MPI:
Includes: -I/home/walker/MPI/mpich2-1.0.8-install/include
X11:
Includes:
Library: -lX11
BLAS/LAPACK: -llapack -lblas
PETSc:
PETSC_ARCH: linux-gnu-c-debug
PETSC_DIR: /home/walker/Desktop/PETSc/LITE/petsc-3.1-p4
Clanguage: C
shared libraries: disabled
dynamic libraries: disabled
Scalar type: real
Precision: double
Memory alignment: 16
xxx=========================================================================xxx
Configure stage complete. Now build PETSc libraries with:
make PETSC_DIR=/home/walker/Desktop/PETSc/LITE/petsc-3.1-p4
PETSC_ARCH=linux-gnu-c-debug all
Is this the same information that would be contained in the log file for the
configuration?
On Fri, Nov 12, 2010 at 10:07 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> You have not set your PETSC_ARCH and PETSC_DIR
> On Nov 12, 2010, at 9:43 AM, Nunion wrote:
> > Hello,
> > I recently started receiving the following error when trying to compile
> anything...
> > makefile:16: /conf/variables: No such file or directory
> > makefile:17: /conf/rules: No such file or directory
> > makefile:858: /conf/test: No such file or directory
> > make: *** No rule to make target `/conf/test'. Stop.
> > The errors seem to be related to one another. I tried to hardcode this
> path, but the makefile is not picking up the path. I can't recall changing
> anything major
> > Thanks!
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101112/e1ae1ece/attachment.htm>
