[petsc-users] Petsc with Intel Fortran
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Fri Nov 5 01:18:17 CDT 2010
This is quite odd.  The symbol __intel_sse2_strlen should be provided
by libirc.a (which should be brought in by icc or icpc, the Intel
C/C++ compilers).  I am surprised that configure passed with this
error.  What C compiler are you supplying to PETSc configure?
I suggest you send the complete configure.log and the results of the
make to petsc-maint at mcs.anl.gov
A
On Fri, Nov 5, 2010 at 7:22 AM, Sharat N <sharatnreddy at gmail.com> wrote:
> Hi,
> I configured the petsc system with intel fortran compiler. This time when I
> did 'make' on any fortran example. It compiled but gave me 1 warning and 1
> error.
> 1)  warning: feupdateenv is not implemented and will always fail
> I found out that This warning is due to a mismatch of library types and can
> be ignored. The warning will not appear if -shared-intel is used.
> 2) symbol lookup error:
> /opt/intel/Compiler/11.1/072/lib/intel64/libifcore.so.5: undefined symbol:
> __intel_sse2_strlen
> This error is not executing my program does anyone know what is the reasons
> for this error and how can we solve it?
> Sharat
