[petsc-users] Boomeramg as a solver
jibum kim
jzk164 at psu.edu
Mon Nov 1 14:46:28 CDT 2010
Are you saying that boomeramg with richardson iterations is same as the
multigrid without a preconditioner? and if it the case, how can I set an
extra preconditioner like ILU ?
- Jibum
----- Original Message -----
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Sent: Monday, November 01, 2010 2:25 PM
Subject: Re: [petsc-users] Boomeramg as a solver
On Nov 1, 2010, at 12:35 PM, jibum kim wrote:
> Hello,
> I've used Boomeramg as a preconditioner.
> Now, I am wondering whether I can use Boomeramg as a solver ? and is it
> possible that I use Boomeramg as both a preconditioner and a solver?
> I saw one slide saying that I can use KSPSetType(ksp, KSPRICHARDSON);
> But when I try it and use -ksp_view, it shows that my solver is Richardson
> not Boomeramg.
> Could u clarify this issue ?
Richardson is our name for the iterative process u^{n+1} = u^n + B(b - A
u^n) for n=1,...max_it where B is the application of the preconditioner (in
other words running a linear iterative method without any Krylov
acceleration). In BoomerAMG's case B is one application of the V or W cycle
(depending on your choice of BoomerAMG options). So even though it says the
"solver" is Richardson it is using BoomerAMG for the entire solution
process, that is algebraic multigrid with multiple V (or W cycles).
Barry
> Thank you.
> - Jibum
