[petsc-users] DAGlobalToLocalBegin()
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Wed Mar 24 16:12:23 CDT 2010
Dear Matt,
Thanks a lot!
Yes, when
-dmmg_iscoloring_type global
is applied, this is right now. But what is difference between
IS_COLORING_GHOSTED and IS_COLORING_GLOBAL?
Cheers,
Rebecca
Quoting Matthew Knepley <knepley at gmail.com>:
> On Wed, Mar 24, 2010 at 3:01 PM, (Rebecca) Xuefei YUAN
> <xy2102 at columbia.edu>wrote:
>> Dear Jed and Matt,
> This is a genuine bug. It is in DMMGComputeJacobianWithFD() and only occurs
> when
> IS_COLORING_GHOSTED is true. So, using IS_COLORING_GLOBAL would probably
> work here (can't look up the option right now).
> Barry, what is supposed to happen here? Clearly a local vector is being
> passed where
> a global vector is expected (at least part of the time).
>    Matt
>> Yes, X and F are global and localFIELD is serial. I ran with np=2.
>> The error I get is:
>>  0 SNES Function norm 1.095445115010e+01
>> [1]PETSC ERROR: VecScatterBegin() line 1538 in src/vec/vec/utils/vscat.c
>> Vector wrong size 100 for scatter 60 (scatter forward and vector from != ctx
>> from size)
>> [0]PETSC ERROR: VecScatterBegin() line 1538 in src/vec/vec/utils/vscat.c
>> from size)
>> from gdb, I get:
>> Program received signal SIGABRT, Aborted.
>> [Switching to Thread 0xb7c396b0 (LWP 6301)]
>> 0xb7f09410 in __kernel_vsyscall ()
>> (gdb) where
>> #0  0xb7f09410 in __kernel_vsyscall ()
>> #1  0xb7c89085 in raise () from /lib/tls/i686/cmov/libc.so.6
>> #2  0xb7c8aa01 in abort () from /lib/tls/i686/cmov/libc.so.6
>> #3  0x087d591d in PetscAbortErrorHandler (line=1538,
>>    fun=0x88fe26d "VecScatterBegin", file=0x88fd9f7 "vscat.c",
>>    dir=0x88fd9ff "src/vec/vec/utils/", n=60, p=1,
>>    mess=0xbfd31124 "Vector wrong size 100 for scatter 60 (scatter forward
>> and v
>> ector from != ctx from size)", ctx=0x0) at errabort.c:62
>> #4  0x0874a88e in PetscError (line=1538, func=0x88fe26d "VecScatterBegin",
>>    file=0x88fd9f7 "vscat.c", dir=0x88fd9ff "src/vec/vec/utils/", n=60, p=1,
>>    mess=0x88fe3a0 "Vector wrong size %D for scatter %D (scatter forward and
>> vec
>> tor from != ctx from size)") at err.c:482
>> #5  0x086558cc in VecScatterBegin (inctx=0x8a393b0, x=0x8b39cc0,
>> y=0x8b3b310,
>>    addv=INSERT_VALUES, mode=SCATTER_FORWARD) at vscat.c:1538
>> #6  0x0828b54c in DAGlobalToLocalBegin (da=0x8a2d360, g=0x8b39cc0,
>>    mode=INSERT_VALUES, l=0x8b3b310) at dagtol.c:50
>> #7  0x080f1b25 in FormFunction (snes=0x8a47840, X=0x8b39cc0, F=0x8adb2f0,
>>    dummg=0x8a2b810) at twgcqt2unffnictv.c:8382
>> #8  0x0860c63d in MatFDColoringApply_AIJ (J=0x8a6bbb0, coloring=0x8aa7b40,
>>    x1=0x8b12a60, flag=0xbfd32164, sctx=0x8a47840) at fdmatrix.c:680
>> #9  0x0860abaf in MatFDColoringApply (J=0x8a6bbb0, coloring=0x8aa7b40,
>>    x1=0x8b12a60, flag=0xbfd32164, sctx=0x8a47840) at fdmatrix.c:521
>> #10 0x08122e45 in SNESDefaultComputeJacobianColor (snes=0x8a47840,
>> ---Type <return> to continue, or q <return> to quit---
>>    x1=0x8b12a60, J=0x8a47910, B=0x8a47914, flag=0xbfd32164, ctx=0x8aa7b40)
>>    at snesj2.c:49
>> #11 0x0811c7cf in DMMGComputeJacobianWithFD (snes=0x8a47840, x1=0x8a39c20,
>>    J=0x8a47910, B=0x8a47914, flag=0xbfd32164, ctx=0x8a2b810) at
>> damgsnes.c:365
>> #12 0x0811a883 in DMMGComputeJacobian_Multigrid (snes=0x8a47840,
>> X=0x8a39c20,
>>    J=0x8a47910, B=0x8a47914, flag=0xbfd32164, ptr=0x8a2b6b0) at
>> damgsnes.c:60
>> #13 0x080fc610 in SNESComputeJacobian (snes=0x8a47840, X=0x8a39c20,
>>    A=0x8a47910, B=0x8a47914, flg=0xbfd32164) at snes.c:1188
>> #14 0x08124471 in SNESSolve_LS (snes=0x8a47840) at ls.c:189
>> #15 0x08103fac in SNESSolve (snes=0x8a47840, b=0x0, x=0x8a39c20) at
>> snes.c:2242
>> #16 0x0811db31 in DMMGSolveSNES (dmmg=0x8a2b6b0, level=0) at damgsnes.c:510
>> #17 0x08117029 in DMMGSolve (dmmg=0x8a2b6b0) at damg.c:313
>> #18 0x08052ecc in Solve (dmmg=0x8a2b6b0) at twgcqt2unffnictv.c:679
>> #19 0x0804def5 in main (argc=Cannot access memory at address 0x189d
>> ) at twgcqt2unffnictv.c:303
>> Same things happened to ex25.c from
>> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/snes/examples/tutorials/ex25.c.html
>> with
>>  ierr = DMMGSetSNES(dmmg,FormFunction,0);CHKERRQ(ierr);
>> //  ierr =
>> DMMGSetSNESLocal(dmmg,FormFunctionLocal,0,ad_FormFunctionLocal,0);CHKERRQ(ierr);
>> Thanks a lot!
>> Rebecca
>> Quoting Jed Brown <jed at 59A2.org>:
>>  On Wed, 24 Mar 2010 15:41:38 -0400, "(Rebecca) Xuefei YUAN"  <
>>> xy2102 at columbia.edu> wrote:
>>>> Hi,all,
>>>> I have an error from
>>>> ierr = DAGlobalToLocalBegin(dafield,X,INSERT_VALUES,localFIELD);
>>>> CHKERRQ(ierr);
>>>> where
>>>> ierr = DMMGSetSNES(dmmg, FormFunction,0);CHKERRQ(ierr); is used for
>>>> set up the SNES.
>>>> So I check up the vector size of X, F, localFIELD where
>>>>        ierr = DAGetLocalVector(dafield,&localFIELD);CHKERRQ(ierr);
>>>>        PetscInt        nlocalFIELD,nX,nF;
>>>>        ierr = VecGetSize(localFIELD,&nlocalFIELD);CHKERRQ(ierr);
>>>>        ierr = VecGetSize(X,&nX);CHKERRQ(ierr);
>>>>        ierr = VecGetSize(F,&nF);CHKERRQ(ierr);
>>>> CHKERRQ(ierr);
>>>>        ierr =
>>>>  DAGlobalToLocalEnd(dafield,X,INSERT_VALUES,localFIELD);CHKERRQ(ierr);
>>>>        ierr =
>>>> DAVecGetArray(dafield,localFIELD,&localfield);CHKERRQ(ierr);
>>>> (gdb) disp nX
>>>> 1: nX = 120
>>>> (gdb) disp nF
>>>> 2: nF = 120
>>>> (gdb) disp nlocalFIELD
>>>> 3: nlocalFIELD = 100
>>> Is this run in parallel?  Note that the sizes of X and F are global,
>>> while localFIELD is serial.  What error did you get?
>>> Matt, it's clearly FormFunction and not FormFunctionLocal because the
>>> function prototype has the SNES.
>>> Jed
>> Department of Applied Physics and Applied Mathematics
>> Columbia University
>> Tel:917-399-8032
>> www.columbia.edu/~xy2102
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
Columbia University
Tel:917-399-8032
