[petsc-users] PetscSplitOwnerShip()
(Rebecca) Xuefei YUAN xy2102 at columbia.edu
Tue Mar 9 17:16:46 CST 2010
I ran np=4 for a small (-da_grid_x 6, -da_grid_y 5) problem, with
PETSC_STENCIL_BOX and width=2, dof = 4.
When I use vecLoad() to load the binary file with the following set:
     PetscViewerBinaryOpen(PETSC_COMM_WORLD,fileName,FILE_MODE_READ,&viewer);
     VecLoad(viewer,PETSC_NULL,&FIELD);
     ierr = DAVecGetArray(da2_4,FIELD,&field);CHKERRQ(ierr);
     ierr = DAVecRestoreArray(da2_4,FIELD,&field);CHKERRQ(ierr);
     ierr = VecDestroy(FIELD);CHKERRQ(ierr);
     ierr = DADestroy(da2_4);CHKERRQ(ierr);
     ierr = PetscViewerDestroy(viewer);CHKERRQ(ierr);
However, I got the error messages as below:
[0]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/dagetarray.c
Vector local size 32 is not compatible with DA local sizes 36 100
[1]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/dagetarray.c
[2]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/dagetarray.c
Vector local size 28 is not compatible with DA local sizes 24 80
[3]PETSC ERROR: DAVecGetArray() line 53 in src/dm/da/src/dagetarray.c
Then I tracked down and tried to find how this 32,32,28,28 coming from.
It turns out that my da2_4 has the parameters at each processor:
       xs xe ys ye x y Xs Xe Ys Ye Nl base nlocal Nlocal
p0:   0  12 0  3 12 3 0  20 0  5  100 0   100    36
p1:   12 24 0  3 12 3 4  24 0  5  100 36  100    36
p2:   0  12 3  5 12 2 0  20 1  5  80  72   80    24
p3:   12 24 3  5 12 2 4  24 1  5  80  96   80    24
and deep in
#0  PetscSplitOwnership (comm=-2080374782, n=0x8a061b4, N=0x8a061b8)
     at psplit.c:81
#1  0x08628384 in PetscLayoutSetUp (map=0x8a061b0) at pmap.c:140
#2  0x08618320 in VecCreate_MPI_Private (v=0x8a05c50, alloc=PETSC_TRUE,
     nghost=0, array=0x0) at pbvec.c:182
#3  0x08618ba7 in VecCreate_MPI (vv=0x8a05c50) at pbvec.c:232
#4  0x085f1554 in VecSetType (vec=0x8a05c50, method=0x885dd0b "mpi")
     at vecreg.c:54
#5  0x085ec4f0 in VecSetTypeFromOptions_Private (vec=0x8a05c50)
     at vector.c:1335
#6  0x085ec909 in VecSetFromOptions (vec=0x8a05c50) at vector.c:1370
#7  0x085d7a7e in VecLoad_Binary (viewer=0x89f70b0, itype=0x885ce3d "mpi",
     newvec=0xbfe148e4) at vecio.c:228
#8  0x085d70e4 in VecLoad (viewer=0x89f70b0, outtype=0x885ce3d "mpi",
     newvec=0xbfe148e4) at vecio.c:134
#9  0x0804f140 in FormInitialGuess_physical (dmmg=0x89a2880, X=0x89b34f0)
     at vecviewload_out.c:390
#10 0x08052ced in DMMGSolve (dmmg=0x89a2720) at damg.c:307
#11 0x0804d479 in main (argc=-1, argv=0xbfe14cd4) at vecviewload_out.c:186
it says that
       *n = *N/size + ((*N % size) > rank);
where *N = 30; size = 4; rank = 0,1,2,3, in such a case, this gives me
*n = 32,32,28,28 for pro0,1,2,3, separately.
Where could be wrong with this mismatch of the local vector size and
da local size(excluding ghost pts or including ghost pts)?
Thanks so much!
Rebecca
