[petsc-users] amg from hypre
hxie at umn.edu hxie at umn.edu
Mon Mar 8 13:53:09 CST 2010
When I use  -ksp_monitor_true_residual, I get
1 223 KSP preconditioned resid norm 7.587441767451e-05 true resid norm
1.919239379677e-07 ||Ae||/||Ax|| 4.636852053066e-07
2 500 500 KSP preconditioned resid norm 2.984438235355e-06 true resid norm
1.067989408349e-08 ||Ae||/||Ax|| 9.216680867037e-03
3 500 KSP preconditioned resid norm 4.928211668435e-07 true resid norm
2.134107616561e-09 ||Ae||/||Ax|| 1.995810570512e-01
4 500 KSP preconditioned resid norm 1.251658900301e-07 true resid norm
3.922169991045e-10 ||Ae||/||Ax|| 1.837856779354e-01
5 500 KSP preconditioned resid norm 4.086703850989e-08 true resid norm
1.521775833365e-10 ||Ae||/||Ax|| 3.879931422346e-01
It is strange to me to get a different true residual by adding the
following codes:
!--compute the norm of true residual-----
       call MatMult(ptMat,ptSol,ptRes,pterr)
       call VecAXPY(ptRes,-1.0,ptRHS,pterr)
       call VecNorm(ptRes,NORM_2,rmax,pterr)
>Linear solve converged due to CONVERGED_RTOL iterations 223
 >field      1       223   0.414E+00
>I printed the real residuals by computing ||b-Ax||_2  at the last column:
> equation  iter    gm_its    gmres
>Linear solve did not converge due to DIVERGED_ITS iterations 500
 >field      2      500   0.116E-05
> field      3       500   0.922E-08
 >field      4     500   0.182E-08
 >field      5      500   0.256E-09
Nothing wrong with the inner linear systems. I chose "gmres rtol" as 1.0d-6
and "gmres atol" as 1.d-10 for the preconditioned system.
>This is the problem. The inner linear systems are just not really being
>solved. Have you looked at
>the convergence (-ksp_monitor)? You can get different nonlinear iteration
>counts this way.
>  Matt
