[petsc-users] How to write and load a SEQSBAIJ matrix?
Barry Smith
bsmith at mcs.anl.gov
Mon Mar 1 10:50:57 CST 2010
On Mar 1, 2010, at 5:21 AM, Zhifeng Sheng - EWI wrote:
> Dear all
> I am trying to generate a system and save it for later usage... I
> used the function MatView and Matload. they work perfectly with
> SEQAIJ matrix
> but when comes to symmetric SEQSBAIJ matrix, they do work. It seems
> that MatView does not put any information into the *.info file..
Sorry, this is our mistake. If you edit src/mat/impls/sbaij/seq/
sbaij.c and replace the function
#undef __FUNCT__
#define __FUNCT__ "MatView_SeqSBAIJ"
PetscErrorCode MatView_SeqSBAIJ(Mat A,PetscViewer viewer)
PetscErrorCode ierr;
PetscTruth iascii,isdraw;
FILE *file = 0;
PetscFunctionBegin;
ierr =
PetscTypeCompare
((PetscObject)viewer,PETSC_VIEWER_ASCII,&iascii);CHKERRQ(ierr);
ierr =
PetscTypeCompare
((PetscObject)viewer,PETSC_VIEWER_DRAW,&isdraw);CHKERRQ(ierr);
if (iascii){
ierr = MatView_SeqSBAIJ_ASCII(A,viewer);CHKERRQ(ierr);
} else if (isdraw) {
ierr = MatView_SeqSBAIJ_Draw(A,viewer);CHKERRQ(ierr);
} else {
Mat B;
ierr = MatConvert(A,MATSEQAIJ,MAT_INITIAL_MATRIX,&B);CHKERRQ(ierr);
ierr = MatView(B,viewer);CHKERRQ(ierr);
ierr = MatDestroy(B);CHKERRQ(ierr);
ierr = PetscViewerBinaryGetInfoPointer(viewer,&file);CHKERRQ(ierr);
if (file) {
fprintf(file,"-matload_block_size %d\n",(int)A->rmap->bs);
PetscFunctionReturn(0);
and run make in that directory it will now save the block size.
Thanks for pointing out the problem,
Barry
> Does any know how to write and load a SEQSBAIJ matrix?
> Thanks and best regards
> Zhifeng
