[petsc-users] ublas sparse matrix bindings?
Luke Bloy luke.bloy at gmail.com
Tue Jun 29 11:39:06 CDT 2010
Aron,
Thanks for the reply. Thats unfortunate i was hoping to use petsc/slepc
on  matrices of doubles and of ints within the same application. I was
hoping to keep the ints for a smaller memory footprint as I'm already in
the >10g range. but it seems like that is possible.
-Luke
On 06/29/2010 11:30 AM, Aron Ahmadia wrote:
> You couldn't simply template the dereference, you would need to have a
> way to reformat the data into single/double-precision, and PETSc
> assumes you are giving it a raw C pointer.  This would have the effect
> of potentially generating an expensive data copy every time you need
> to hand your object to PETSc.  I think you would be much better served
> by deciding ahead of time whether you will need a single or
> double-precision PETSc and writing your code accordingly with that
> assumption.
> A
> On Tue, Jun 29, 2010 at 6:21 PM, Umut Tabak <u.tabak at tudelft.nl
> <mailto:u.tabak at tudelft.nl>> wrote:
>     Luke Bloy wrote:
>         Thanks for the response. Thats unfortunate as i use many
>         different types of matrices that i would like use with petsc.
>         I'm not much of a c++ whiz,
>     me neither ;)
>         but i'm curious if something like an adaptor would be possible
>         that would make a
>         (float *) behave like a (petscscalar *) as far as petsc was
>         concerned? Thoughts?
>     I am not sure if these kinds of pointer conversions are safe if
>     you do not know that what 'petscscalar *' really is, you might
>     check the docs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100629/2fc91991/attachment.htm>
