[petsc-users] ublas sparse matrix bindings?
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Tue Jun 29 10:30:23 CDT 2010
You couldn't simply template the dereference, you would need to have a way
to reformat the data into single/double-precision, and PETSc assumes you are
giving it a raw C pointer.  This would have the effect of potentially
generating an expensive data copy every time you need to hand your object to
PETSc.  I think you would be much better served by deciding ahead of time
whether you will need a single or double-precision PETSc and writing your
code accordingly with that assumption.
A
On Tue, Jun 29, 2010 at 6:21 PM, Umut Tabak <u.tabak at tudelft.nl> wrote:
> Luke Bloy wrote:
>> Thanks for the response. Thats unfortunate as i use many different types
>> of matrices that i would like use with petsc.
>> I'm not much of a c++ whiz,
> me neither ;)
>  but i'm curious if something like an adaptor would be possible that would
>> make a
>> (float *) behave like a (petscscalar *) as far as petsc was concerned?
>> Thoughts?
> I am not sure if these kinds of pointer conversions are safe if you do not
> know that what 'petscscalar *' really is, you might check the docs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100629/703cc2c0/attachment.htm>
