[petsc-users] PETSc4Py with Enthough Python Distribution
Amal Alghamdi
amal.ghamdi at kaust.edu.sa
Sun Jun 13 07:03:07 CDT 2010
Dear Mr. Barry and Mr. Lisandro,
Thank you very much for the help. I tried installing
PETSc4Py independently after installing PETSc and it seems working.
Best regards,
Amal
On Sun, Jun 13, 2010 at 3:38 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 12 June 2010 20:45, Amal Alghamdi <amal.ghamdi at kaust.edu.sa> wrote:
> > Dear All,
> > I have Mac OS 10.6 and I'd like to ask if any one have tried using
> PETSc4Py
> > with Enthough Python Distribution, EPD. I have tried to build PETSc with
> the
> > option --download-petsc4py but it complained that I am not using the
> system
> > python
> > realpath of /usr/lib/libpython.dylib
> > (/System/Library/Frameworks/Python.framework/Versions/2.6/Python) does
> not
> > point to Python library path
> > (/Library/Frameworks/Python.framework/Versions/6.1/Python) for current
> > Python;
> > Are you not using the Apple python?
> > Does that mean I should use Apple python or there is a way to make
> PETSc4Py
> > works on EPD.
> > Thank you very much
> > Amal
> You could also try to build petsc4py independently, after building
> core PETSc. Just download the tarball release, export PETSC_DIR=...
> PETSC_ARCH=..., and then "python setup.py build". Note however that
> you may still run into trouble in this OS X + EPD Python combination.
> It's not my fault, the universal binaries thing in OS X plus the
> custom way EPD builds Python is hard to deal with, specially as I do
> not have any OS X box to do proper testing. If you cannot make it
> work, feel free to contact me privately and be prepared to help me a
> bit.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100613/677040fc/attachment.htm>
