[petsc-users] jacobi before ilu with shifting
Barry Smith
bsmith at mcs.anl.gov
Tue Jul 27 14:50:18 CDT 2010
Run with -help | grep shift to see what the exact name of the prefix/option is
Barry
On Jul 27, 2010, at 2:34 PM, SUN Chun wrote:
> Hi Petsc dev,
> I couldn't figure out this preconditioner setting... I want to do BJACOBI + ILU on each block with shifting, but before ILU I want to apply a diagonal scaling to my LHS. What I've been trying to do is:
> -pc_type bjacobi
> -sub_pc_type composite
> -sub_pc_composite_type multiplicative
> -sub_pc_composite_pcs jacobi,ilu
> then I don't know where to add -pc_factor_shift_positive_definite I've tried adding "sub_", "sub_pc_composite_" prefixes to that but non worked.
> I wonder if the whole idea of using composite is wrong. Where should I scale it? Where should I specify shifting?
> Thanks,
> Chun
> This email and any attachments are intended solely for the use of the individual or entity to whom it is addressed and may be confidential and/or privileged.
> If you are not one of the named recipients or have received this email in error,
> (i) you should not read, disclose, or copy it,
> (ii) please notify sender of your receipt by reply email and delete this email and all attachments,
> (iii) Dassault Systemes does not accept or assume any liability or responsibility for any use of or reliance on this email.
> For other languages, Click Here
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100727/9e6d00f2/attachment.htm>
