[petsc-users] about speed
Xuan YU
xxy113 at psu.edu
Mon Jul 26 16:00:52 CDT 2010
On Jul 26, 2010, at 3:53 PM, Barry Smith wrote:
> ./configure an optimized version of PETSc (that is with the ./
> configure flag of --with-debugging=0)
./configure --with -debugging=0
it says I should config/configure.py --with-mpi=0 --with-debugging=no
--download-f-blas-lapack=1
so I did this.
When I compile my code again, I got:
gcc -Wall -Wwrite-strings -Wno-strict-aliasing -O -o pihm pihm.o f.o
read_alloc.o initialize.o is_sm_et.o update.o print.o -Wl,-rpath,/gpfs/
home/xxy113/soft/petsc-3.1-p2/linux-gnu-c-opt/lib -L/gpfs/home/xxy113/
soft/petsc-3.1-p2/linux-gnu-c-opt/lib -lpetsc -lX11 -Wl,-rpath,/
gpfs/home/xxy113/soft/petsc-3.1-p2/linux-gnu-c-opt/lib -L/gpfs/home/
xxy113/soft/petsc-3.1-p2/linux-gnu-c-opt/lib -lflapack -lfblas -lm -L/
usr/lib/gcc/x86_64-redhat-linux/4.1.2 -ldl -lgcc_s -lgfortran -lm -lm -
ldl -lgcc_s -ldl
/usr/bin/ld: cannot find -lpetsc
collect2: ld returned 1 exit status
> and run with -log_summary to get a summary of where it is spending
> the time.
> This will give you a better idea of why it is taking so long.
> Barry
> On Jul 26, 2010, at 2:49 PM, Xuan YU wrote:
>> Hi,
>> I am using TS solving a nonlinear problem. I created an approximate
>> data structure for Jacobian matrix to be used with matcoloring, my
>> MatFDColoringView is like this:
>> <Picture 1.png>
>> But the speed of code is too slow than what I expected. Only 10
>> time step costs 11seconds!
>> What's wrong with my code? How can I speed up?
>> Thanks!
>> This is the ts_view result.
>> TS Object:
>> type: beuler
>> maximum steps=100
>> maximum time=10
>> total number of nonlinear solver iterations=186
>> total number of linear solver iterations=423
>> SNES Object:
>> type: ls
>> line search variant: SNESLineSearchCubic
>> alpha=0.0001, maxstep=1e+08, minlambda=1e-12
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=1
>> total number of function evaluations=19
>> KSP Object:
>> type: gmres
>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>> GMRES: happy breakdown tolerance 1e-30
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object:
>> type: ilu
>> ILU: out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 1e-12
>> using diagonal shift to prevent zero pivot
>> matrix ordering: natural
>> factor fill ratio given 1, needed 1
>> Factored matrix follows:
>> Matrix Object:
>> type=seqaij, rows=1838, cols=1838
>> package used to perform factorization: petsc
>> total: nonzeros=8464, allocated nonzeros=8464
>> total number of mallocs used during MatSetValues calls =0
>> not using I-node routines
>> linear system matrix = precond matrix:
>> Matrix Object:
>> total: nonzeros=8464, allocated nonzeros=9745
>> total number of mallocs used during MatSetValues calls =37
>> Xuan YU
>> xxy113 at psu.edu
Xuan YU (俞烜)
xxy113 at psu.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100726/513a6d18/attachment-0001.htm>
