[petsc-users] about speed
Barry Smith
bsmith at mcs.anl.gov
Mon Jul 26 14:53:14 CDT 2010
./configure an optimized version of PETSc (that is with the ./configure flag of --with-debugging=0) and run with -log_summary to get a summary of where it is spending the time. This will give you a better idea of why it is taking so long.
Barry
On Jul 26, 2010, at 2:49 PM, Xuan YU wrote:
> Hi,
> I am using TS solving a nonlinear problem. I created an approximate data structure for Jacobian matrix to be used with matcoloring, my MatFDColoringView is like this:
> <Picture 1.png>
> But the speed of code is too slow than what I expected. Only 10 time step costs 11seconds!
> What's wrong with my code? How can I speed up?
> Thanks!
> This is the ts_view result.
> TS Object:
> type: beuler
> maximum steps=100
> maximum time=10
> total number of nonlinear solver iterations=186
> total number of linear solver iterations=423
> SNES Object:
> type: ls
> line search variant: SNESLineSearchCubic
> alpha=0.0001, maxstep=1e+08, minlambda=1e-12
> maximum iterations=50, maximum function evaluations=10000
> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> total number of linear solver iterations=1
> total number of function evaluations=19
> KSP Object:
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object:
> type: ilu
> ILU: out-of-place factorization
> 0 levels of fill
> tolerance for zero pivot 1e-12
> using diagonal shift to prevent zero pivot
> matrix ordering: natural
> factor fill ratio given 1, needed 1
> Factored matrix follows:
> Matrix Object:
> type=seqaij, rows=1838, cols=1838
> package used to perform factorization: petsc
> total: nonzeros=8464, allocated nonzeros=8464
> total number of mallocs used during MatSetValues calls =0
> not using I-node routines
> linear system matrix = precond matrix:
> Matrix Object:
> total: nonzeros=8464, allocated nonzeros=9745
> total number of mallocs used during MatSetValues calls =37
> Xuan YU
> xxy113 at psu.edu
