[petsc-users] configure problems
Farshid Mossaiby mossaiby at yahoo.com
Thu Jul 22 03:07:57 CDT 2010
I doubt 'cl' can interpret Cygwin paths:
cl : Command line warning D9002 : ignoring unknown option
'/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
Shouldn't win32fe convert this path first?
Hope this helps.
--- On Wed, 7/21/10, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> From: Dominik Szczerba <dominik at itis.ethz.ch>
> Subject: Re: [petsc-users] configure problems
> To: "PETSc users list" <petsc-users at mcs.anl.gov>
> Date: Wednesday, July 21, 2010, 7:01 PM
> Coming back to the original problem:
> I tried to compile MPICH2 myself
> and failed because of wrong version of automake in Cygwin.
> I then
> installed the Windows binary available on the mpich2
> webpage. I
> configure petsc with:
> $ ./config/configure.py PETSC_DIR=$PWD
> PETSC_ARCH=win64-msvc-release
> --download-c-blas-lapack=1
> --with-mpi-dir='/cygdrive/c/Program
> Files/MPICH2' --with-x=0 --with-debugging=0
> --with-cc='win32fe cl'
> --with-fc=0
> to hear at the end (of a very long configuration
> process...):
> sh:
> /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe
> cl  -o conftest.exe    -MT -wd4996
> conftest.o  /cygdrive/c/Program\
> Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> Executing:
> sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> conftest.obj : error LNK2019: unresolved external symbol
> _MPI_Init
> referenced in function _main
> C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal
> error
> LNK1120: 1 unresolved externals
> Any directions why would the configuration look for a
> nonexistent
> library? The contents of the installation folder are:
> $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> total 808
> drwx------+ 1 SYSTEM SYSTEM   4096
> 2010-07-21 15:54 .
> 2010-07-21 15:54 ..
> -rwx------+ 1 SYSTEM SYSTEM   4644
> 2010-02-22 17:13 TraceInput.lib
> -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09
> cxx.lib
> -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11
> fmpich2.lib
> -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13
> fmpich2g.lib
> -rwx------+ 1 SYSTEM SYSTEM   1936
> 2010-02-22 17:13 irlog2rlog.lib
> -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30
> mpe.lib
> -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29
> mpi.lib
> -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30
> rlog.lib
> Best regards,
> Dominik
> On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org>
> wrote:
> > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley
> <knepley at gmail.com>
> wrote:
> >> This would do you absolutely no good. Even Jed's
> thing needs all the
> >> information that the configure provides. CMake is
> exactly what it
> >> says, make. It does no configuration
> > This isn't true, CMake isn't a build system at all, it
> does
> > configuration and produces build files for another
> tool (like make or an
> > IDE).  I see no point in maintaining duplicate
> configuration systems,
> > and CMake's scripting language is so attrocious that
> "replacing"
> > BuildSystem with CMake script would be a disaster.
>  It's
> > cross-compilation support is also a bit weak, and
> there are a pile of
> > other things that it does poorly (mostly related to
> pathologically
> > dysfunctional "Find*.cmake" modules).  That doesn't
> mean it isn't useful
> > for producing build files.
> > Jed
