[petsc-users] configure problems
Dominik Szczerba dominik at itis.ethz.ch
Wed Jul 21 17:07:01 CDT 2010
OK. Now the configuration breaks with the ending:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
You must specify a path for MPI with --with-mpi-dir=<directory>
If you do not want MPI, then give --with-mpi=0
You might also consider using --download-mpi instead
I am posting the whole log to the other list.
Dominik
On Wed, Jul 21, 2010 at 11:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 21 Jul 2010, Dominik Szczerba wrote:
> > I assume you mean in addition --with-mpi=0, else I am expecting an error
> > message.
> I meant without --with-mpi=0 [or any other MPI option]. In this case
> configure searches in default paths [assuming MPICH2 was installed in
> standard location].
> Looks like it didn't work for you. So - can you send the corresponding
> configure.log to petsc-maint?
> Satish
> > Configure did not bring up any errors:
> > Compilers:
> >   C Compiler:
> > /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/bin/win32fe/win32fe cl
>  -MT
> > -wd4996
> > Linkers:
> >   Static linker:   /usr/bin/ar cr
> > BLAS/LAPACK:
> > -L/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3/win64-msvc-release/lib
> > -lf2clapack -L/cygdrive/c/Users/Dominik/P
> > -lf2cblas
> > PETSc:
> >   PETSC_ARCH: win64-msvc-release
> >   PETSC_DIR: /cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3
> >   Clanguage: C
> >   Scalar type: real
> >   Precision: double
> >   Memory alignment: 16
> >   shared libraries: disabled
> >   dynamic libraries: disabled
> xxx=========================================================================xxx
> >    Configure stage complete. Now build PETSc libraries with:
> >    make PETSC_DIR=/cygdrive/c/Users/Dominik/Programs/petsc-3.1-p3
> > PETSC_ARCH=win64-msvc-release all
> > Building was also successful. Test run OK (with 1 MPI process)
> > My LIB:
> > C:\Program Files (x86)\Microsoft Visual Studio
> 9.0\VC\ATLMFC\LIB;C:\Program
> > Files (x86)\Microsoft Visual Studio 9.0\VC\LIB;C:\Program Files\Microsoft
> > SDKs\Windows\v6.0A\lib;
> > Many thanks for any hints how to get a usable MPICH2 installation,
> > Dominik
> > On Wed, Jul 21, 2010 at 6:09 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Try:
> > > ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> > > --download-c-blas-lapack=1 --with-x=0 --with-debugging=0
> --with-cc='win32fe
> > > cl' --with-fc=0
> > > If it fails - send us configure.log at petsc-maint at mcs.anl.gov
> > > BTW: What do you have in your LIB env variable? [MS search this path
> for
> > > libraries by default]
> > > echo $LIB
> > > Satish
> > > > Coming back to the original problem: I tried to compile MPICH2 myself
> > > > and failed because of wrong version of automake in Cygwin. I then
> > > > installed the Windows binary available on the mpich2 webpage. I
> > > > configure petsc with:
> > > > $ ./config/configure.py PETSC_DIR=$PWD PETSC_ARCH=win64-msvc-release
> > > > --download-c-blas-lapack=1 --with-mpi-dir='/cygdrive/c/Program
> > > > Files/MPICH2' --with-x=0 --with-debugging=0 --with-cc='win32fe cl'
> > > > --with-fc=0
> > > > to hear at the end (of a very long configuration process...):
> > > > sh:
> > > > cl  -o conftest.exe    -MT -wd4996  conftest.o  /cygdrive/c/Program\
> > > > Files/MPICH2/lib/amd64/msmpi.lib Ws2_32.lib
> > > > Executing:
> > > > sh: Warning: win32fe: File Not Found: /cygdrive/c/Program
> > > > cl : Command line warning D9002 : ignoring unknown option
> > > > '/cygdrive/c/Program Files/MPICH2/lib/amd64/msmpi.lib'
> > > > conftest.obj : error LNK2019: unresolved external symbol _MPI_Init
> > > > referenced in function _main
> > > > C:\Users\Dominik\Programs\PETSC-~1.1-P\conftest.exe : fatal error
> > > > LNK1120: 1 unresolved externals
> > > > Any directions why would the configuration look for a nonexistent
> > > > library? The contents of the installation folder are:
> > > > $ ls -la /cygdrive/c/Program\ Files/MPICH2/lib/
> > > > total 808
> > > > drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 .
> > > > drwx------+ 1 SYSTEM SYSTEM   4096 2010-07-21 15:54 ..
> > > > -rwx------+ 1 SYSTEM SYSTEM   4644 2010-02-22 17:13 TraceInput.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 322820 2010-02-22 17:09 cxx.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 131316 2010-02-22 17:11 fmpich2.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 136382 2010-02-22 17:13 fmpich2g.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM   1936 2010-02-22 17:13 irlog2rlog.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM  10430 2010-02-22 16:30 mpe.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM 132128 2010-02-22 16:29 mpi.lib
> > > > -rwx------+ 1 SYSTEM SYSTEM  61286 2010-02-22 16:30 rlog.lib
> > > > Best regards,
> > > > Dominik
> > > > On Tue, Jul 20, 2010 at 12:44 AM, Jed Brown <jed at 59a2.org> wrote:
> > > > > On Tue, 20 Jul 2010 08:37:18 +1000, Matthew Knepley <
> knepley at gmail.com>
> > > wrote:
> > > > >> This would do you absolutely no good. Even Jed's thing needs all
> the
> > > > >> information that the configure provides. CMake is exactly what it
> > > > >> says, make. It does no configuration
> > > > > This isn't true, CMake isn't a build system at all, it does
> > > > > configuration and produces build files for another tool (like make
> or
> > > an
> > > > > IDE).  I see no point in maintaining duplicate configuration
> systems,
> > > > > and CMake's scripting language is so attrocious that "replacing"
> > > > > BuildSystem with CMake script would be a disaster.  It's
> > > > > cross-compilation support is also a bit weak, and there are a pile
> of
> > > > > other things that it does poorly (mostly related to pathologically
> > > > > dysfunctional "Find*.cmake" modules).  That doesn't mean it isn't
> > > useful
> > > > > for producing build files.
> > > > > Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100722/3b3c1253/attachment-0001.htm>
