[petsc-users] Collective abort of all ranks
Thu Jul 8 21:59:08 CDT 2010
  Take out the CHKERRQ() AFTER the PetscFinalize() that may be the problem.
  If not, I think you are basically stuck running in the debugger to see what is generating the message.
   barry
On Jul 8, 2010, at 5:42 PM, Немања Илић (Nemanja Ilic) wrote:
> Hello,
> I am developing a PETSc application and I encountered the following problem:
> My parallel program does everything ok, finishes the meaningful job, and near the end it breaks with the following line:
> "rank 0 in job 17  wg_49925   caused collective abort of all ranks
>  exit status of rank 0: killed by signal 9"
> It happends regardless of number of processes in the job.
> Here is the ending of the function 'calculate' which does the work:
> 	// write result to file
> 	PetscViewer viewer;
> 	ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD, output_file_name, &viewer); CHKERRQ(ierr);
> 	ierr = PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_COMMON); CHKERRQ(ierr);
> 	ierr = VecView(bp, viewer); CHKERRQ(ierr);
> 	// clean-up
> 	ierr = MatDestroy(Ap); CHKERRQ(ierr);
> 	ierr = VecDestroy(bp); CHKERRQ(ierr);
> 	ierr = VecDestroy(xp); CHKERRQ(ierr);
> 	free(col);
> 	free(row);
> 	free(row_values);
> 	return b;"
> The file 'viewer' is outputed correctly.
> When 'calculate' finishes the finalization function gets called:
> 	"ierr = PetscFinalize(); CHKERRQ(ierr);"
> Does anyone have any idea to why my program breaks?
> Thank you in advance,
> Best regards,
> Nemanja Ilic
> PS
> Sorry if this is not the right place for my question :)
