[petsc-users] Collective abort of all ranks
Немања Илић (Nemanja Ilic) nemanja.ilic.81 at gmail.com
Thu Jul 8 17:42:41 CDT 2010
Hello,
I am developing a PETSc application and I encountered the following problem:
My parallel program does everything ok, finishes the meaningful job, and near the end it breaks with the following line:
"rank 0 in job 17  wg_49925   caused collective abort of all ranks
  exit status of rank 0: killed by signal 9"
It happends regardless of number of processes in the job.
Here is the ending of the function 'calculate' which does the work:
	// write result to file
	PetscViewer viewer;
	ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD, output_file_name, &viewer); CHKERRQ(ierr);
	ierr = PetscViewerSetFormat(viewer, PETSC_VIEWER_ASCII_COMMON); CHKERRQ(ierr);
	ierr = VecView(bp, viewer); CHKERRQ(ierr);
	// clean-up
	ierr = MatDestroy(Ap); CHKERRQ(ierr);
	ierr = VecDestroy(bp); CHKERRQ(ierr);
	ierr = VecDestroy(xp); CHKERRQ(ierr);
	free(col);
	free(row);
	free(row_values);
	return b;"
The file 'viewer' is outputed correctly.
When 'calculate' finishes the finalization function gets called:
	"ierr = PetscFinalize(); CHKERRQ(ierr);"
Does anyone have any idea to why my program breaks?
Thank you in advance,
Best regards,
Nemanja Ilic
PS
Sorry if this is not the right place for my question :)
