[petsc-users] MatMult with factored matrix
Daniel L Crumly
daniel.crumly at Colorado.EDU
Thu Jul 8 12:06:09 CDT 2010
Hello all -
Is there a recommended way to multiply a factored matrix by a vector
(effectively MatMult where the matrix is a factored matrix or
preconditioner)? Specifically, I would like to get take the ILU
factorization of a matrix, then multiply a vector by this approximation.
What I currently have is:
ierr = PCGetType(pc, &pctype);CHKERRQ(ierr);
if (strcmp(pctype, PCILU) == 0 || strcmp(pctype, PCICC) == 0) {
ierr = PCFactorGetMatrix(pc, &M);CHKERRQ(ierr);
ierr = MatMult(M, x, Mx);CHKERRQ(ierr);
which throws the runtime error (I'm currently using PETSc 3.0.0-p8.):
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: Not for factored matrix!
[0]PETSC ERROR:
Any suggestions are greatly appreciated, thank you.
Daniel "The Plaid Mentat" Crumly
Daniel.Crumly at colorado.edu
I give you the desert chameleon, whose ability to blend itself into the
background tells you all you need to know about the roots of ecology and the
foundations of a personal identity.
--Book of Diatribes from the Hayt Chronicle
----Herbert, Frank. Children of Dune 28.
