[petsc-users] my code runs too slow
abhyshr at mcs.anl.gov abhyshr at mcs.anl.gov
Wed Jul 7 14:26:24 CDT 2010
Use TSComputeDefaultJacobian instead of SNESComputeDefaultJacobian if you want to use TS objects only.
> ierr = TSComputeDefaultJacobian(ts,t,CV_Y,&J,&J,&flag,PETSC_NULL);CHKERRQ(ierr);
> ierr = MatGetColoring(J,MATCOLORINGSL,&iscoloring);CHKERRQ(ierr);
> ierr = MatFDColoringCreate(J,iscoloring,&matfdcoloring);CHKERRQ(ierr);
> ierr = ISColoringDestroy(iscoloring);CHKERRQ(ierr); ...you missed this
> ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode (*)(void))f,(void*)&appctx);CHKERRQ(ierr);
> ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr);
> ierr = TSSetRHSJacobian(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);
Shri
> ----- "Xuan YU" <xxy113 at psu.edu> wrote:
> > ierr = MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,10,PETSC_NULL,&J);CHKERRQ(ierr);
ierr = MatAssemblyBegin(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = MatAssemblyEnd(J,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
ierr = SNESComputeJacobian(ts_snes,CV_Y,&J,&J,&flag);CHKERRQ(ierr);
These are the Jacobian related codes.
On Jul 7, 2010, at 1:51 PM, Satish Balay wrote:
total: nonzeros=1830
mallocs used during MatSetValues calls =1830
> > Looks like you are zero-ing out the non-zero structure - before
> > assembling the matrix.
> > Are you calling MatZeroRows() or MatZeroEntries() or something else -
> > before assembling the matrix?
> > Satish
> > On Wed, 7 Jul 2010, Xuan YU wrote:
I made a change: ierr =
MatCreateSeqAIJ(PETSC_COMM_SELF,N,N,5,PETSC_NULL,&J);CHKERRQ(ierr);
Time of the code did not change much, and got the info:
Matrix Object:
type=seqaij, rows=1830, cols=1830
total: nonzeros=1830, allocated nonzeros=36600
total number of mallocs used during MatSetValues calls =1830
not using I-node routines
On Jul 7, 2010, at 12:51 PM, Satish Balay wrote:
total: nonzeros=1830, allocated nonzeros=29280
There is something wrong with your preallocation or matrix
assembly. You should see zero mallocs for efficient assembly.
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#efficient-assembly
satish
I finite difference Jacobian approximation for my TS model. The size of
the
vector is 1830. I got the following info with(-ts_view):
type: beuler
maximum steps=50
maximum time=50
total number of nonlinear solver iterations=647
total number of linear solver iterations=647
SNES Object:
type: ls
line search variant: SNESLineSearchCubic
alpha=0.0001, maxstep=1e+08, minlambda=1e-12
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
total number of linear solver iterations=50
total number of function evaluations=51
KSP Object:
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object:
type: ilu
ILU: out-of-place factorization
0 levels of fill
tolerance for zero pivot 1e-12
using diagonal shift to prevent zero pivot
matrix ordering: natural
factor fill ratio given 1, needed 1
Factored matrix follows:
Matrix Object:
package used to perform factorization: petsc
total: nonzeros=1830, allocated nonzeros=1830
total number of mallocs used during MatSetValues calls =0
linear system matrix = precond matrix:
Matrix Object:
50 output time step takes me 11.877s. So I guess there is something not
appropriate with my Jacobian Matrix. Could you please tell me how to speed
up
my code?
Thanks!
Xuan YU
xxy113 at psu.edu
Xuan YU (俞烜)
xxy113 at psu.edu
Xuan YU ( 俞烜 )
xxy113 at psu.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100707/19a1f9cd/attachment-0001.htm>
