[petsc-users] Petsc parallel processing from a library, without "mpiexec -np ..."
Satish Balay
balay at mcs.anl.gov
Tue Jul 6 13:45:11 CDT 2010
One additional point: If using 'parallel processing' - then you
shouldn't be trying to circumvent this part of MPI standard [mpiexec -n].
And if you are primarily doing sequential stuff - you can build PETSc
with '--with-mpi=0' [so MPI is not used. However when working with
multiple MPI software packages there could be issues here - so its
recommended to use a proper MPI impl like MPICH2 across all these
software packages]
Satish
On Tue, 6 Jul 2010, Aron Ahmadia wrote:
> Dear Nemanja,
> Welcome to PETSc! It is important to note that PETSc's parallel
> functionality is implemented on top of MPI. Your MPI vendor (Microsoft,
> MPICH, OpenMPI, etc...) is responsible for providing you the interface for
> launching your jobs in parallel, PETSc does not care how your MPI jobs are
> launched. Although mpiexec is the standard on UNIXy-style operating systems
> and distributions, it is not uncommon to see graphical interfaces for
> launching these programs in the OS X and Microsoft HPC worlds.
> I suggest that you raise this question with the implementors/providers of
> your MPI libraries (PETSc downloads and installs mpich:
> http://www.mcs.anl.gov/research/projects/mpich2/ for you in many standard
> configurations).
> Good luck,
> Aron
> On Tue, Jul 6, 2010 at 7:43 PM, Немања Илић (Nemanja Ilic) <
> nemanja.ilic.81 at gmail.com> wrote:
> > Hello,
> > I am currently working on a project involving Petsc library. My core
> > library that uses Petsc has several functionalities that are invoked via
> > function calls. Is there a way to call these functions from another library
> > and to have parallel processing, without using "mpiexec -np ..." command
> > line format?
> > Thank you in advance,
> > Best regards,
> > Nemanja Ilic
