[petsc-users] Errors while install pets-dev
(Rebecca) Xuefei YUAN
xy2102 at columbia.edu
Mon Jan 25 23:03:00 CST 2010
Dear Satish,
Yes, I do have problems with external packages, so I downloaded them
manually and move them into petsc-dev.
So the configure has options like
rebecca at YuanWork:~/soft/petsc-dev$ ./config/configure.py --with-cc=gcc
--with-fc=gfortran
--download-f-blas-lapack=/home/rebecca/soft/petsc-dev/fblaslapack-3.1.1.tar.gz
--download-mpich=/home/rebecca/soft/petsc-dev/mpich2-1.2.1.tar.gz
--download-sowing=/home/rebecca/soft/petsc-dev/sowing-1.1.15.tar.gz
--download-c2html=/home/rebecca/soft/petsc-dev/c2html.tar.gz
The Fortran compiler I have is g77 and gfortran.
If I do not use Fortran, will this be fine?
Cheers,
Rebecca
Quoting Satish Balay <balay at mcs.anl.gov>:
> Ok - is your manual install '2. access tarballs directly from our
> mercurial server.?
> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
> And do you have problem with --download-pacakge options due to the
> proxy issues? If so - that might explain the problem.
> petsc-dev - with 'hg' - or with 'tarballs from mercurial' server
> require sowing package for the fortran interface. If configure is
> unable to install sowing - then fortran interface is not generated.
> Thus unresolved symbol errors when compiling fortran examples.
> This can be verified by looking at configure.log and make.log for this
> build.
> Satish
> On Mon, 25 Jan 2010, Satish Balay wrote:
>> On Mon, 25 Jan 2010, (Rebecca) Xuefei YUAN wrote:
>> > Dear Satish,
>> > I switched to install it manually
>> What do you mean? Did you get the nightly tarball?
>> > and encounter an error when "make test".
>> Did the build go through fine without errors??
>> Send over configure.log and make.log to petsc-maint.
>> Satish
>> > Here are error messages:
>> > Completed building libraries
>> > Now to check if the libraries are working do: make test
>> > rebecca at YuanWork:~/soft/petsc-dev$ make test
>> > Running test examples to verify correct installation
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI
>> > process
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2 MPI
>> > processes
>> > --------------Error detected during compile or
>> link!-----------------------
>> > See
>> http://www.mcs.anl.gov/petsc/petsc-2/documentation/troubleshooting.html
>> > /home/rebecca/soft/petsc-dev/linux-gnu-c-debug/bin/mpif90 -c -Wall
>> > -Wno-unused-variable -g
>> > -I/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/include
>> > -I/home/rebecca/soft/petsc-dev/include
>> > -I/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/include -o
>> ex5f.o ex5f.F
>> > /home/rebecca/soft/petsc-dev/linux-gnu-c-debug/bin/mpif90 -Wall
>> > -Wno-unused-variable -g -o ex5f ex5f.o
>> > -Wl,-rpath,/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/lib
>> > -L/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/lib -lpetscsnes
>> -lpetscksp
>> > -lpetscdm -lpetscmat -lpetscvec -lpetsc -lX11
>> > -L/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/lib -lflapack
>> -lfblas -lnsl
>> > -lrt -lm -L/home/rebecca/soft/petsc-dev/linux-gnu-c-debug/lib
>> > -L/usr/lib/gcc/i486-linux-gnu/4.2.4 -ldl -lmpich -lopa -lpthread
>> -lrt -lgcc_s
>> > -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa -lpthread -lrt
>> -lgcc_s -ldl
>> > ex5f.o: In function `MAIN__':
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:103:
>> undefined
>> > reference to `snescreate_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:120:
>> undefined
>> > reference to `dacreateglobalvector_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:121:
>> undefined
>> > reference to `vecduplicate_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:131:
>> undefined
>> > reference to `dagetcorners_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:133:
>> undefined
>> > reference to `dagetghostcorners_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:211:
>> undefined
>> > reference to `snessetfromoptions_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:223:
>> undefined
>> > reference to `snesgetiterationnumber_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:235:
>> undefined
>> > reference to `matdestroy_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:236:
>> undefined
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:237:
>> undefined
>> > reference to `vecdestroy_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:238:
>> undefined
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:239:
>> undefined
>> > reference to `snesdestroy_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:240:
>> undefined
>> > reference to `dadestroy_'
>> > ex5f.o: In function `forminitialguess_':
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:286:
>> undefined
>> > reference to `dmgetlocalvector_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:299:
>> undefined
>> > reference to `dalocaltoglobal_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:300:
>> undefined
>> > reference to `dmrestorelocalvector_'
>> > ex5f.o: In function `formjacobianlocal_':
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:523:
>> undefined
>> > reference to `matsetvalueslocal_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:538:
>> undefined
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:542:
>> undefined
>> > reference to `matassemblybegin_'
>> /home/rebecca/soft/petsc-dev/src/snes/examples/tutorials/ex5f.F:543:
>> undefined
>> > reference to `matassemblyend_'
>> > collect2: ld returned 1 exit status
>> > make[3]: [ex5f] Error 1 (ignored)
>> > /bin/rm -f ex5f.o
>> > Completed test examples
>> > What could possibly wrong?
>> > Thanks!
>> > Rebecca
>> > > Sorry - forgot to mention the url
>> http://mail.openjdk.java.net/pipermail/build-dev/2007-December/000628.html
>> > > Satish
>> > > > Do you have to use proxy for your http connections? If so - perhaps
>> > > > you can try adding the settings to ~/.hgrc - as this url indicates and
>> > > > see if it fixes the problem.
>> > > > Satish
>> > > > > Hi,All,
>> > > > > I try to install a pets-dev locally according to the instruction
>> > > > > I have installed mercurial, but when I get the second step,
>> I get some
>> > > > > error
>> > > > > like:
>> > > > > rebecca at YuanWork:~/soft$ hg clone
>> > > > > http://petsc.cs.iit.edu/petsc/petsc-dev
>> > > > > destination directory: petsc-dev
>> > > > > abort: error: Name or service not known
>> > > > > Is there anything wrong?
>> > > > > Thanks!
Department of Applied Physics and Applied Mathematics
Columbia University
Tel:917-399-8032
www.columbia.edu/~xy2102
