[petsc-users] petsc-users Digest, Vol 13, Issue 28
Thu Jan 21 14:11:16 CST 2010
On Thu, Jan 21, 2010 at 2:07 PM, Jack Lee <jack.lee at sjc.ox.ac.uk> wrote:
> Thanks for the reply. Perhaps I should have explained a little further:
> > 1) MUMPS is a linear solver
> I am aware of that, what I meant was that instead of the default iterative
> solver which snes employs, I'd like the option of being able to use an
> external solver for each linear solution of the non-linear loop.
Okay
> > 2)
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFactorSetMatSolverPackage.html
> Currently I am applying these steps:
> 1. set ksp context extracted from snes to pre only
> 2. set pc type to lu
> 3. set pc factor solver package to MUMPS, as you've explained above.
> However, having no examples to compare to, I'm not 100% sure if this is the
> way it's supposed to be done.
Yep, that is it
> > 3) There is a manual section on this
> if you're talking about page 83, it doesn't spell out the case which I'm
> trying to apply to, so thought I'd better double-check.
> > 4) You can use command line options in Fortran
> Not in the custom fortran application we're building, which is compiled as
> a library. We're linking in petsc to exploit its fantastic solver
> capabilities....
Well, when you call PetscInitialize(), in Fortran, it is reading the command
line arguments. You, of course, do not have
to use them, but they are there.
  Matt
> Cheers,
> Jack
> petsc-users-request at mcs.anl.gov wrote:
>> Send petsc-users mailing list submissions to
>>        petsc-users at mcs.anl.gov
>> To subscribe or unsubscribe via the World Wide Web, visit
>>        https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>>        petsc-users-owner at mcs.anl.gov
>> When replying, please edit your Subject line so it is more specific
>> than "Re: Contents of petsc-users digest..."
>> Today's Topics:
>>   1.  using external direct linear solvers (Jack Lee)
>>   2. Re:  using external direct linear solvers (Matthew Knepley)
>>   3.  using PETSC with visual studio 2005? (Zhifeng Sheng - EWI)
>>   4. Re:  using PETSC with visual studio 2005? (Satish Balay)
>> Message: 1
>> Date: Wed, 20 Jan 2010 22:50:47 +0000
>> From: Jack Lee <jack.lee at sjc.ox.ac.uk>
>> Subject: [petsc-users] using external direct linear solvers
>> To: petsc-users at mcs.anl.gov
>> Message-ID: <4B5788C7.20902 at sjc.ox.ac.uk>
>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>> Hi there,
>> Apologies if this is an obvious question, but is there an example showing
>> how to call an external solver? I am trying to get the snes solver to use
>> MUMPS. As the calls are made from a fortran application, I cannot use the
>> commandline options.
>> Jack
>> Message: 2
>> Date: Wed, 20 Jan 2010 17:14:16 -0600
>> From: Matthew Knepley <knepley at gmail.com>
>> Subject: Re: [petsc-users] using external direct linear solvers
>> To: PETSc users list <petsc-users at mcs.anl.gov>
>> Message-ID:
>>        <a9f269831001201514x473b849ci76cc9ab80d754586 at mail.gmail.com>
>> Content-Type: text/plain; charset="iso-8859-1"
>> On Wed, Jan 20, 2010 at 4:50 PM, Jack Lee <jack.lee at sjc.ox.ac.uk> wrote:
>>  Hi there,
>> 2)
>>  Matt
>> Jack
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100121/01089ea5/attachment.htm>
