[petsc-users] petsc-users Digest, Vol 13, Issue 28
Jack Lee jack.lee at sjc.ox.ac.uk
Thu Jan 21 14:07:31 CST 2010
Thanks for the reply. Perhaps I should have explained a little further:
 > 1) MUMPS is a linear solver
I am aware of that, what I meant was that instead of the default
iterative solver which snes employs, I'd like the option of being able
to use an external solver for each linear solution of the non-linear loop.
 > 2)
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/PC/PCFactorSetMatSolverPackage.html
Currently I am applying these steps:
1. set ksp context extracted from snes to pre only
2. set pc type to lu
3. set pc factor solver package to MUMPS, as you've explained above.
However, having no examples to compare to, I'm not 100% sure if this is
the way it's supposed to be done.
 > 3) There is a manual section on this
if you're talking about page 83, it doesn't spell out the case which I'm
trying to apply to, so thought I'd better double-check.
 > 4) You can use command line options in Fortran
Not in the custom fortran application we're building, which is compiled
as a library. We're linking in petsc to exploit its fantastic solver
capabilities....
Cheers,
Jack
petsc-users-request at mcs.anl.gov wrote:
> Send petsc-users mailing list submissions to
> 	petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
>    1.  using external direct linear solvers (Jack Lee)
>    2. Re:  using external direct linear solvers (Matthew Knepley)
>    3.  using PETSC with visual studio 2005? (Zhifeng Sheng - EWI)
>    4. Re:  using PETSC with visual studio 2005? (Satish Balay)
> Message: 1
> Date: Wed, 20 Jan 2010 22:50:47 +0000
> From: Jack Lee <jack.lee at sjc.ox.ac.uk>
> Subject: [petsc-users] using external direct linear solvers
> To: petsc-users at mcs.anl.gov
> Message-ID: <4B5788C7.20902 at sjc.ox.ac.uk>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Hi there,
> Apologies if this is an obvious question, but is there an example
> showing how to call an external solver? I am trying to get the snes
> solver to use MUMPS. As the calls are made from a fortran application, I
> cannot use the commandline options.
> Jack
> Message: 2
> Date: Wed, 20 Jan 2010 17:14:16 -0600
> From: Matthew Knepley <knepley at gmail.com>
> Subject: Re: [petsc-users] using external direct linear solvers
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
> 	<a9f269831001201514x473b849ci76cc9ab80d754586 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> On Wed, Jan 20, 2010 at 4:50 PM, Jack Lee <jack.lee at sjc.ox.ac.uk> wrote:
>> Hi there,
>> Apologies if this is an obvious question, but is there an example showing
>> how to call an external solver? I am trying to get the snes solver to use
>> MUMPS. As the calls are made from a fortran application, I cannot use the
> 2)
>   Matt
> Jack
