[petsc-users] ParMETIS question
Tue Dec 21 10:31:01 CST 2010
On Tue, Dec 21, 2010 at 5:49 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Hi,
> I have a not directly PETSc related question, but I hope to get some answer
> from the community here. In my FEM code, I make use of ParMETIS to partition
> the mesh. I make direct use of this library and not of PETSc's ParMETIS
> integration. The initial partition is always fine, but I use the
> ParMETIS_V3_AdaptiveRepart function for repartition the mesh due to local
> mesh adaption. In most cases, the result is fine, but there are two points,
> where I have trouble with:
> 1) Sometimes ParMETIS generates empty partitions, i.e., a processor has
> zero mesh elements. This is something my code cannot handle. Is this a bug
> or a feature? If it is a feature, is there any possiblity to disable it?
ParMetis has a balance constraint if you weight vertices. This will enforce
equal size partitions.
> 2) In most cases the specific partitions are not connected. If I put all
> data to ParMETIS in a correct way, is this okay? My code can handle it, but
> is slows down the computation due to larger interior boundaries and
> therefore to more communications.
ParMetis minimizes the overall boundary size, so I do not understand how you
could see this slowdown.
   Matt
> Does anyone of you know an answer to these question? Is there a debug mode
> in ParMETIS, where I can see which data is set to its function calls?
> Regards,
> Thomas
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101221/205fc2ce/attachment.htm>
