[petsc-users] GPU-enabled PETSc
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Dec 10 08:12:42 CST 2010
http://www.mcs.anl.gov/petsc/petsc-as/features/gpus.html
since this is only supported in petsc-dev suggest moving any future discussion of these issues to petsc-dev at mcs.anl.gov
  Barry
On Dec 10, 2010, at 4:36 AM, Moinier, Pierre (UK) wrote:
> Hi,
> Can any one tell me where to find a documentation that gives details on
> the GPU-enabled PETSc version? I looked in the archive mailing list as
> well as the petsc-dev doc folder, but did not find anything. What I am
> looking for are how the implementation is done, what is currently done
> and some examples...
> Regards,
> 	-Pierre.
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
