[petsc-users] GPU-enabled PETSc
Moinier, Pierre (UK) Pierre.Moinier at baesystems.com
Fri Dec 10 04:36:10 CST 2010
Can any one tell me where to find a documentation that gives details on
the GPU-enabled PETSc version? I looked in the archive mailing list as
well as the petsc-dev doc folder, but did not find anything. What I am
looking for are how the implementation is done, what is currently done
and some examples...
	-Pierre.
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
