[petsc-users] configure script for petsc
Satish Balay
balay at mcs.anl.gov
Fri Apr 23 08:47:22 CDT 2010
On Fri, 23 Apr 2010, Stephan Kramer wrote:
> > > Hi all,
> > > I'm trying to write a portable configure script for our software that uses
> > > petsc, and needs to deal with petsc installations on a number of different
> > > platforms. In petsc 3.0 I could do
> > > make -f $(PETSC_DIR)/conf/base getlinklibs
> > > and
> > > make -f $(PETSC_DIR)/conf/base getincludedirs
> > > that would work for both "installed" petsc and petsc in its own build
> > > directory (provided PETSC_ARCH is set correctly of course). In petsc 3.1
> > > conf/base seems to have disappeared, is the best
> > > way to deal with this to make my own little makefile:
> > > include ${PETSC_DIR}/conf/variables
> > > include ${PETSC_DIR}/conf/rules
> > > and use "make -f my_own_little_makefile getlinklibs" instead?
> > Yes - this way - you can add more stuff into this makefile - if needed.
> > If you just do getlinklibs and getincludedirs - then you can probably
> > just do:
> > make -f $(PETSC_DIR)/makefile getincludedirs
> True, except the makefile doesn't make it into a prefix-installed
> installation of petsc. Having my own makefile do it works fine -
> was just checking if this is indeed the recommended way
Ah yes. There is no makefie that you can use in the prefix install. In
this case creating a temporary makefile is the way to go..
Satish
