[petsc-users] configure script for petsc
    Stephan Kramer
    s.kramer at imperial.ac.uk
    Fri Apr 23 08:39:33 CDT 2010
Satish Balay wrote:
> On Fri, 23 Apr 2010, Stephan Kramer wrote:
>> Hi all,
>> I'm trying to write a portable configure script for our software that uses
>> petsc, and needs to deal with petsc installations on a number of different
>> platforms. In petsc 3.0 I could do
>>   make -f $(PETSC_DIR)/conf/base getlinklibs
>> and
>>   make -f $(PETSC_DIR)/conf/base getincludedirs
>> that would work for both "installed" petsc and petsc in its own build
>> directory (provided PETSC_ARCH is set correctly of course). In petsc 3.1
>> conf/base seems to have disappeared, is the best
>> way to deal with this to make my own little makefile:
>> include ${PETSC_DIR}/conf/variables
>> include ${PETSC_DIR}/conf/rules
>> and use "make -f my_own_little_makefile getlinklibs" instead?
> Yes - this way - you can add more stuff into this makefile - if needed.
> If you just do getlinklibs and getincludedirs - then you can probably
> just do:
> make -f $(PETSC_DIR)/makefile getincludedirs
True, except the makefile doesn't make it into a prefix-installed
installation of petsc. Having my own makefile do it works fine -
  was just checking if this is indeed the recommended way
Thanks a lot
Cheers
Stephan
> etc..
> Satish
Stephan Kramer  <s.kramer at imperial.ac.uk>
Applied Modelling and Computation Group,
Department of Earth Science and Engineering,
Imperial College London
