[petsc-users] petsc-users Digest, Vol 16, Issue 23
Li, Zhisong (lizs) lizs at mail.uc.edu
Mon Apr 19 16:28:47 CDT 2010
Hi, Jed
Yes, I did have "--download-mpich=1" when I installed PETSc.  To use "--with-mpi-dir=/path/to/system/mpi ?", Do you mean I should reinstall PETSc with this option or add this as a run command option? It seems it's not recognized as a run command option.
Anyway, this should be a fundamental issue running PETSc. Why doesn't it happen to many other users? On machines of Ohio supercomputer center, I could not easily install any software for myself. I can only upload my complied executable and run it there using their default MPI setup.
Zhisong Li
From: Jed Brown [five9a2 at gmail.com] on behalf of Jed Brown [jed at 59A2.org]
Sent: Monday, April 19, 2010 4:12 PM
To: Li, Zhisong (lizs); petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] petsc-users Digest, Vol 16, Issue 23
On Mon, 19 Apr 2010 20:05:06 +0000, "Li, Zhisong (lizs)" <lizs at mail.uc.edu> wrote:
> Mat and Jed,
> Thank you for your reply.
> As far as I remembered, the make test was successful except the Fortran complier, but I only use C for my work.
> I tried " $ cd src/snes/examples/tutorials && make -n ex5" and it shows: /home/lizs/petsc/linux-gnu-c-debug/bin/mpicc  ex5.c  -o  ex5
Looks like configure has built an MPI for you.  Did you use
--download-mpich ?
> All the machines have mpi package installed before I got to touch
> PETSc.
Maybe you wanted to use --with-mpi-dir=/path/to/system/mpi ?
Jed
