[petsc-users] ML and -pc_factor_shift_nonzero
tribur at vision.ee.ethz.ch
Fri Apr 16 06:51:13 CDT 2010
Dear Barry and Matt,
thanks for your helpful response.
ML works now using, e.g., -mg_coarse_redundant_pc_factor_shift_type
POSITIVE_DEFINITE. However, it converges very slowly using the default
REDUNDANT for the coarse solve. On 10 processors, e.g., even bjacobi
plus -mg_coarse_ksp_max_it 10 works better. What solver do you
recommend for the coarse solve? Maybe superlu?
Best regards,
Kathrin
Quoting "Barry Smith" <bsmith at mcs.anl.gov>:
> -mg_coarse_pc_factor_shift_nonzero since it is the coarse level of
> the multigrid that is producing the zero pivot.
> Barry
> On Apr 13, 2010, at 8:51 AM, Matthew Knepley wrote:
>> On Tue, Apr 13, 2010 at 2:49 PM, <tribur at vision.ee.ethz.ch> wrote:
>> Hi,
>> using ML I got the error
>> "[0]PETSC ERROR: Detected zero pivot in LU factorization"
>> As recommended at
>> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html ,
>> I tried -pc_factor_shift_nonzero but it doesn't have the desired
>> effect using ML.
>> How do I have to formulate the command line option? What does -
>> [level]_pc_factor_shift_nonzero mean? What other parallel
>> preconditioner could I try besides Hypre/Boomeramg or ML?
>> This means the MG level, like 2. You can see all available options
>> using -help.
>> Matt
>> Thanks in advance for your precious help,
>> Kathrin
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
