[petsc-users] Error during compiling my own code
Fri Apr 16 01:35:49 CDT 2010
> >> /app1/mvapich2/current/include/mpif.h(9): error #6401: The attributes of
> >> this name conflict with those made accessible by a USE statement.
> >> [MPI_SOURCE]
> >>        INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
You are using some module - based on the 'use' statement refered by
the error above. And this module must be including mpif.h [or using
mpi.mod] directly or indirectly - so you'll have to debug this fortran
code issue.
Or - send us a sample code we can use to reporduces this problem -
Without that we are just shooting in the dark..
Satish
On Fri, 16 Apr 2010, Wee-Beng Tay wrote:
> Hi Matt,
> Nope, not in the file I'm trying to compile. Everything seems fine before.
> On Fri, Apr 16, 2010 at 12:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > It looks like you have conflicting definitions. Did you include "use mpi"?
> >    Matt
> > On Thu, Apr 15, 2010 at 10:53 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
> >> Hi Matt,
> >> I'm using petsc-3.1-p0. But it's now working. I only use 1 #include
> >> "finclude/petsc.h" now.
> >> However when another of my f90 file has mpi command inside, I got the
> >> error:
> >> [MPI_SOURCE]
> >> [MPI_TAG]
> >> [MPI_ERROR]
> >> What's happening now again?
> >> Thanks!
> >> On Fri, Apr 16, 2010 at 11:38 AM, Matthew Knepley <knepley at gmail.com>wrote:
> >>> If you are using petsc-dev, you only need petsc.h
> >>>    Matt
> >>> On Thu, Apr 15, 2010 at 10:27 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
> >>>> Hi,
> >>>> I have successfully built the PETSc libraries no my linux system.
> >>>> make ex1f also works.
> >>>> However, when compiling my own code, I got the error:
> >>>> [atlas5-c01]$ /app1/mvapich2/current/bin/mpif90 -c  -O3
> >>>> -I/home/svu/g0306332/codes/petsc-3.1-p0/atlas5-mpi-nodebug/include
> >>>> -I/home/svu/g0306332/codes/petsc-3.1-p0/include
> >>>> -I/home/svu/g0306332/lib/hypre-2.6.0b_atlas5/include
> >>>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include
> >>>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include    -o global.o
> >>>> global.F -132
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(10):
> >>>> error #6418: This name has already been assigned a data type.   [NORM_1]
> >>>>       integer(kind=selected_int_kind(5)) NORM_1
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(11):
> >>>> error #6418: This name has already been assigned a data type.   [NORM_2]
> >>>>       integer(kind=selected_int_kind(5)) NORM_2
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(12):
> >>>> [NORM_FROBENIUS]
> >>>>       integer(kind=selected_int_kind(5)) NORM_FROBENIUS
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(13):
> >>>> [NORM_INFINITY]
> >>>>       integer(kind=selected_int_kind(5)) NORM_INFINITY
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(14):
> >>>> error #6418: This name has already been assigned a data type.   [NORM_MAX]
> >>>>       integer(kind=selected_int_kind(5)) NORM_MAX
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(15):
> >>>> [NORM_1_AND_2]
> >>>>       integer(kind=selected_int_kind(5)) NORM_1_AND_2
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(22):
> >>>> [NOT_SET_VALUES]
> >>>>       integer(kind=selected_int_kind(5)) NOT_SET_VALUES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(23):
> >>>> [INSERT_VALUES]
> >>>>       integer(kind=selected_int_kind(5)) INSERT_VALUES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(24):
> >>>> error #6418: This name has already been assigned a data type.   [ADD_VALUES]
> >>>>       integer(kind=selected_int_kind(5)) ADD_VALUES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(25):
> >>>> error #6418: This name has already been assigned a data type.   [MAX_VALUES]
> >>>>       integer(kind=selected_int_kind(5)) MAX_VALUES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(32):
> >>>> [SCATTER_FORWARD]
> >>>>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(33):
> >>>> [SCATTER_REVERSE]
> >>>>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(34):
> >>>> [SCATTER_FORWARD_LOCAL]
> >>>>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD_LOCAL
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(35):
> >>>> [SCATTER_REVERSE_LOCAL]
> >>>>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE_LOCAL
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(36):
> >>>> [SCATTER_LOCAL]
> >>>>       integer(kind=selected_int_kind(5)) SCATTER_LOCAL
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(44):
> >>>> [VEC_IGNORE_OFF_PROC_ENTRIES]
> >>>>       integer(kind=selected_int_kind(5)) VEC_IGNORE_OFF_PROC_ENTRIES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(45):
> >>>> [VEC_IGNORE_NEGATIVE_INDICES]
> >>>>       integer(kind=selected_int_kind(5)) VEC_IGNORE_NEGATIVE_INDICES
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(53):
> >>>> error #6418: This name has already been assigned a data type.   [VECOP_VIEW]
> >>>>       integer(kind=selected_int_kind(5)) VECOP_VIEW
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(54):
> >>>> [VECOP_LOADINTOVECTOR]
> >>>>       integer(kind=selected_int_kind(5)) VECOP_LOADINTOVECTOR
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(10):
> >>>> [MAT_FLUSH_ASSEMBLY]
> >>>>       integer(kind=selected_int_kind(5)) MAT_FLUSH_ASSEMBLY
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(11):
> >>>> [MAT_FINAL_ASSEMBLY]
> >>>>       integer(kind=selected_int_kind(5)) MAT_FINAL_ASSEMBLY
> >>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(17):
> >>>> error #6418: This name has already been assigned a data type.   [MAT_FACTO
> >>>> I don't remember having this error in prev version of PETSc. May I know
> >>>> what went wrong?
> >>>> The 1st few lines of my code are:
> >>>>     module global_data
> >>>>     implicit none
> >>>>     save
> >>>> #include "finclude/petsc.h"
> >>>> #include "finclude/petscvec.h"
> >>>> #include "finclude/petscmat.h"
> >>>> #include "finclude/petscksp.h"
> >>>> #include "finclude/petscpc.h"
> >>>> #include "finclude/petscsys.h"
> >>>>     integer ::
> >>>> size_x,size_y,Total_time_step,new_start,interval,gridgen,safe_int,OS,airfoil_no
> >>>>     integer ::
> >>>> steady,quasi_steady,Total_k,time,mom_solver,poisson_solver,start_time,motion
> >>>>     !size_x must be in multiples of 37/32/36/40/55/41, !size_y must be
> >>>> in multiples of 26/16/36
> >>>>     !gridgen1 - 32x20, gridgen4 - 30x22, gridgen5 - 30x24
> >>>>     real(8) :: CFL, Re, scheme, B, AA, BB,AB,
> >>>> ld,air_centy,Pi,hy0,k0,freq,phase_ang,theta0,loc_rot
> >>>>     real(8) :: time_sta,act_time,vel_h,vel_hn,inv_Re
> >>>> Thanks alot!
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which their
> >>> experiments lead.
> >>> -- Norbert Wiener
> > experiments lead.
> > -- Norbert Wiener
