[petsc-users] Error during compiling my own code
Matthew Knepley
knepley at gmail.com
Thu Apr 15 23:09:57 CDT 2010
It looks like you have conflicting definitions. Did you include "use mpi"?
Matt
On Thu, Apr 15, 2010 at 10:53 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
> Hi Matt,
> I'm using petsc-3.1-p0. But it's now working. I only use 1 #include
> "finclude/petsc.h" now.
> However when another of my f90 file has mpi command inside, I got the
> error:
> /app1/mvapich2/current/include/mpif.h(9): error #6401: The attributes of
> this name conflict with those made accessible by a USE statement.
> [MPI_SOURCE]
> INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
> [MPI_TAG]
> [MPI_ERROR]
> What's happening now again?
> Thanks!
> On Fri, Apr 16, 2010 at 11:38 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> If you are using petsc-dev, you only need petsc.h
>> Matt
>> On Thu, Apr 15, 2010 at 10:27 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
>>> Hi,
>>> I have successfully built the PETSc libraries no my linux system.
>>> make ex1f also works.
>>> However, when compiling my own code, I got the error:
>>> [atlas5-c01]$ /app1/mvapich2/current/bin/mpif90 -c -O3
>>> -I/home/svu/g0306332/codes/petsc-3.1-p0/atlas5-mpi-nodebug/include
>>> -I/home/svu/g0306332/codes/petsc-3.1-p0/include
>>> -I/home/svu/g0306332/lib/hypre-2.6.0b_atlas5/include
>>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include
>>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include -o global.o
>>> global.F -132
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(10):
>>> error #6418: This name has already been assigned a data type. [NORM_1]
>>> integer(kind=selected_int_kind(5)) NORM_1
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(11):
>>> error #6418: This name has already been assigned a data type. [NORM_2]
>>> integer(kind=selected_int_kind(5)) NORM_2
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(12):
>>> [NORM_FROBENIUS]
>>> integer(kind=selected_int_kind(5)) NORM_FROBENIUS
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(13):
>>> [NORM_INFINITY]
>>> integer(kind=selected_int_kind(5)) NORM_INFINITY
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(14):
>>> error #6418: This name has already been assigned a data type. [NORM_MAX]
>>> integer(kind=selected_int_kind(5)) NORM_MAX
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(15):
>>> [NORM_1_AND_2]
>>> integer(kind=selected_int_kind(5)) NORM_1_AND_2
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(22):
>>> [NOT_SET_VALUES]
>>> integer(kind=selected_int_kind(5)) NOT_SET_VALUES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(23):
>>> [INSERT_VALUES]
>>> integer(kind=selected_int_kind(5)) INSERT_VALUES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(24):
>>> error #6418: This name has already been assigned a data type. [ADD_VALUES]
>>> integer(kind=selected_int_kind(5)) ADD_VALUES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(25):
>>> error #6418: This name has already been assigned a data type. [MAX_VALUES]
>>> integer(kind=selected_int_kind(5)) MAX_VALUES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(32):
>>> [SCATTER_FORWARD]
>>> integer(kind=selected_int_kind(5)) SCATTER_FORWARD
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(33):
>>> [SCATTER_REVERSE]
>>> integer(kind=selected_int_kind(5)) SCATTER_REVERSE
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(34):
>>> [SCATTER_FORWARD_LOCAL]
>>> integer(kind=selected_int_kind(5)) SCATTER_FORWARD_LOCAL
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(35):
>>> [SCATTER_REVERSE_LOCAL]
>>> integer(kind=selected_int_kind(5)) SCATTER_REVERSE_LOCAL
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(36):
>>> [SCATTER_LOCAL]
>>> integer(kind=selected_int_kind(5)) SCATTER_LOCAL
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(44):
>>> [VEC_IGNORE_OFF_PROC_ENTRIES]
>>> integer(kind=selected_int_kind(5)) VEC_IGNORE_OFF_PROC_ENTRIES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(45):
>>> [VEC_IGNORE_NEGATIVE_INDICES]
>>> integer(kind=selected_int_kind(5)) VEC_IGNORE_NEGATIVE_INDICES
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(53):
>>> error #6418: This name has already been assigned a data type. [VECOP_VIEW]
>>> integer(kind=selected_int_kind(5)) VECOP_VIEW
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(54):
>>> [VECOP_LOADINTOVECTOR]
>>> integer(kind=selected_int_kind(5)) VECOP_LOADINTOVECTOR
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(10):
>>> [MAT_FLUSH_ASSEMBLY]
>>> integer(kind=selected_int_kind(5)) MAT_FLUSH_ASSEMBLY
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(11):
>>> [MAT_FINAL_ASSEMBLY]
>>> integer(kind=selected_int_kind(5)) MAT_FINAL_ASSEMBLY
>>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(17):
>>> error #6418: This name has already been assigned a data type. [MAT_FACTO
>>> I don't remember having this error in prev version of PETSc. May I know
>>> what went wrong?
>>> The 1st few lines of my code are:
>>> module global_data
>>> implicit none
>>> save
>>> #include "finclude/petsc.h"
>>> #include "finclude/petscvec.h"
>>> #include "finclude/petscmat.h"
>>> #include "finclude/petscksp.h"
>>> #include "finclude/petscpc.h"
>>> #include "finclude/petscsys.h"
>>> integer ::
>>> size_x,size_y,Total_time_step,new_start,interval,gridgen,safe_int,OS,airfoil_no
>>> integer ::
>>> steady,quasi_steady,Total_k,time,mom_solver,poisson_solver,start_time,motion
>>> !size_x must be in multiples of 37/32/36/40/55/41, !size_y must be in
>>> multiples of 26/16/36
>>> !gridgen1 - 32x20, gridgen4 - 30x22, gridgen5 - 30x24
>>> real(8) :: CFL, Re, scheme, B, AA, BB,AB,
>>> ld,air_centy,Pi,hy0,k0,freq,phase_ang,theta0,loc_rot
>>> real(8) :: time_sta,act_time,vel_h,vel_hn,inv_Re
>>> Thanks alot!
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100415/f2d6c7a1/attachment.htm>
