[petsc-users] Error during compiling my own code
Wee-Beng Tay zonexo at gmail.com
Thu Apr 15 22:53:13 CDT 2010
Hi Matt,
I'm using petsc-3.1-p0. But it's now working. I only use 1 #include
"finclude/petsc.h" now.
However when another of my f90 file has mpi command inside, I got the error:
/app1/mvapich2/current/include/mpif.h(9): error #6401: The attributes of
this name conflict with those made accessible by a USE statement.
[MPI_SOURCE]
       INTEGER MPI_SOURCE, MPI_TAG, MPI_ERROR
[MPI_TAG]
[MPI_ERROR]
What's happening now again?
Thanks!
On Fri, Apr 16, 2010 at 11:38 AM, Matthew Knepley <knepley at gmail.com> wrote:
> If you are using petsc-dev, you only need petsc.h
>    Matt
> On Thu, Apr 15, 2010 at 10:27 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
>> Hi,
>> I have successfully built the PETSc libraries no my linux system.
>> make ex1f also works.
>> However, when compiling my own code, I got the error:
>> [atlas5-c01]$ /app1/mvapich2/current/bin/mpif90 -c  -O3
>> -I/home/svu/g0306332/codes/petsc-3.1-p0/atlas5-mpi-nodebug/include
>> -I/home/svu/g0306332/codes/petsc-3.1-p0/include
>> -I/home/svu/g0306332/lib/hypre-2.6.0b_atlas5/include
>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include
>> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include    -o global.o
>> global.F -132
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(10):
>> error #6418: This name has already been assigned a data type.   [NORM_1]
>>       integer(kind=selected_int_kind(5)) NORM_1
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(11):
>> error #6418: This name has already been assigned a data type.   [NORM_2]
>>       integer(kind=selected_int_kind(5)) NORM_2
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(12):
>> [NORM_FROBENIUS]
>>       integer(kind=selected_int_kind(5)) NORM_FROBENIUS
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(13):
>> [NORM_INFINITY]
>>       integer(kind=selected_int_kind(5)) NORM_INFINITY
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(14):
>> error #6418: This name has already been assigned a data type.   [NORM_MAX]
>>       integer(kind=selected_int_kind(5)) NORM_MAX
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(15):
>> [NORM_1_AND_2]
>>       integer(kind=selected_int_kind(5)) NORM_1_AND_2
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(22):
>> [NOT_SET_VALUES]
>>       integer(kind=selected_int_kind(5)) NOT_SET_VALUES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(23):
>> [INSERT_VALUES]
>>       integer(kind=selected_int_kind(5)) INSERT_VALUES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(24):
>> error #6418: This name has already been assigned a data type.   [ADD_VALUES]
>>       integer(kind=selected_int_kind(5)) ADD_VALUES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(25):
>> error #6418: This name has already been assigned a data type.   [MAX_VALUES]
>>       integer(kind=selected_int_kind(5)) MAX_VALUES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(32):
>> [SCATTER_FORWARD]
>>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(33):
>> [SCATTER_REVERSE]
>>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(34):
>> [SCATTER_FORWARD_LOCAL]
>>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD_LOCAL
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(35):
>> [SCATTER_REVERSE_LOCAL]
>>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE_LOCAL
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(36):
>> [SCATTER_LOCAL]
>>       integer(kind=selected_int_kind(5)) SCATTER_LOCAL
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(44):
>> [VEC_IGNORE_OFF_PROC_ENTRIES]
>>       integer(kind=selected_int_kind(5)) VEC_IGNORE_OFF_PROC_ENTRIES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(45):
>> [VEC_IGNORE_NEGATIVE_INDICES]
>>       integer(kind=selected_int_kind(5)) VEC_IGNORE_NEGATIVE_INDICES
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(53):
>> error #6418: This name has already been assigned a data type.   [VECOP_VIEW]
>>       integer(kind=selected_int_kind(5)) VECOP_VIEW
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(54):
>> [VECOP_LOADINTOVECTOR]
>>       integer(kind=selected_int_kind(5)) VECOP_LOADINTOVECTOR
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(10):
>> [MAT_FLUSH_ASSEMBLY]
>>       integer(kind=selected_int_kind(5)) MAT_FLUSH_ASSEMBLY
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(11):
>> [MAT_FINAL_ASSEMBLY]
>>       integer(kind=selected_int_kind(5)) MAT_FINAL_ASSEMBLY
>> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(17):
>> error #6418: This name has already been assigned a data type.   [MAT_FACTO
>> I don't remember having this error in prev version of PETSc. May I know
>> what went wrong?
>> The 1st few lines of my code are:
>>     module global_data
>>     implicit none
>>     save
>> #include "finclude/petsc.h"
>> #include "finclude/petscvec.h"
>> #include "finclude/petscmat.h"
>> #include "finclude/petscksp.h"
>> #include "finclude/petscpc.h"
>> #include "finclude/petscsys.h"
>>     integer ::
>> size_x,size_y,Total_time_step,new_start,interval,gridgen,safe_int,OS,airfoil_no
>>     integer ::
>> steady,quasi_steady,Total_k,time,mom_solver,poisson_solver,start_time,motion
>>     !size_x must be in multiples of 37/32/36/40/55/41, !size_y must be in
>> multiples of 26/16/36
>>     !gridgen1 - 32x20, gridgen4 - 30x22, gridgen5 - 30x24
>>     real(8) :: CFL, Re, scheme, B, AA, BB,AB,
>> ld,air_centy,Pi,hy0,k0,freq,phase_ang,theta0,loc_rot
>>     real(8) :: time_sta,act_time,vel_h,vel_hn,inv_Re
>> Thanks alot!
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100416/4da61e01/attachment-0001.htm>
