superlu_dist doesn't work in peysc-3.0.0-p1
Ravi Kannan rxk at cfdrc.com
Wed Mar 25 11:26:45 CDT 2009
After I upgrade the petsc from 2.3.3 to 3.0.0, I have made the change for
the superlu from
_ierr = MatSetType(_A,MATSUPERLU_DIST)
to
_ierr = MatSetType(_A,MAT_SOLVER_SUPERLU_DIST)
Is this the only change I need to do?
Ravi, X.G
  -----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov]On Behalf Of Matthew Knepley
  Sent: Wednesday, March 25, 2009 7:08 AM
  To: PETSc users list
  Subject: Re: Petsc parallel vectors with two communicators
  On Wed, Mar 25, 2009 at 1:05 AM, Khan, Irfan <irfan.khan at gatech.edu>
wrote:
    Hi
    Can the petsc parallel vectors be used with two different communicators?
For instance, I have created two different communicators called FEA_Comm and
FSI_Comm. The total number of processes are x+y. FSI_Comm works on x+y but
FEA_Comm works only on x.
    Now I am trying to create parallel vectors a1 and a2 such that a1 has
entries from x+y processes but a2 has entries from only y processes.
    After splitting the communicators I assign PETSC_COMM_WORLD to FEA_Comm
which works on only x processes. Subsequently petsc is initialized
(PetscInitialize()). But when the parallel vectors are created, the
processes hang.
  PETSC_COMM_WORLD should encompass all processes you wish to use in PETSc,
so that means x+y. You can create Vec
  objects on subcommunicators, like x.
    Matt
    Any suggestions will be helpful
    Thankyou
    Irfan
    Graduate Research Assistant
    Woodruff school of Mechanical Engineering
    Atlanta, GA (30307)
experiments lead.
  -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090325/d6fba4c8/attachment.htm>
