Hello for compiled problem
Wei-Dong Lian weidong.lian at gmail.com
Tue Mar 10 10:59:42 CDT 2009
Hello everyone,
I compiled the petsc-3.0.0-p3 with GCC 3.4.3 under linux 64. But the
compiler gave me the following information, see result_1.
I also ran the "make test" and it worked successfully, but when I linked
petsc to compile my programme, it told me that information see results_2.
Any suggestion will be appreciated.
Thank you in advance.
Weidong
$$$$$$$$$$$$$$$$$$$$$Result_1$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
/ftn-custom
g++: option « -PIC » non reconnue
libfast in: /usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/euler
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/rk
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/explicit/rk/ftn-auto
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit/beuler
libfast in:
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/ts/impls/implicit/cn
#####################################results_2################################
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2aaf):
In function `DAGetWireBasketInterpolation(_p_DA*, _p_Mat*, MatReuse,
_p_Mat**)':
/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:201:
undefined reference to `PetscTableCreate(int, _n_PetscTable**)'
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2b3d):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:203:
undefined reference to `PetscTableAddCount(_n_PetscTable*, int)'
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2ba1):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:205:
undefined reference to `PetscTableGetCount(_n_PetscTable*, int*)'
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2d24):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:209:
undefined reference to `PetscTableFind(_n_PetscTable*, int, int*)'
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x2d8d):/usr/local/temp/lian/Develop/latest/Solver/petscSeq/src/dm/da/utils/daint.c:212:
undefined reference to `PetscTableDestroy(_n_PetscTable*)'
/usr/local/temp/lian/Develop/Solver/petscSeq/x86_64_linux/lib/libpetscdm.a(daint.o)(.text+0x5adf):
In function `DAGetFaceInterpolation(_p_DA*, _p_Mat*, MatReuse, _p_Mat**)':
My configuration of petsc:
                            Pushing language C
                            Popping language C
                            Pushing language Cxx
                            Popping language Cxx
                            Pushing language FC
                            Popping language FC
sh: /bin/sh
/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/BuildSystem/config/packages/config.gue
ss
Executing: /bin/sh
fig.guess
sh: x86_64-unknown-linux-gnu
sh: /bin/sh
/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/BuildSystem/config/packages/config.sub
Executing: /bin/sh
fig.sub x86_64-unknown-linux-gnu
Starting Configure Run at Tue Mar 10 16:23:30 2009
Configure Options: --configModules=PETSc.Configure
--optionsModule=PETSc.compilerOptions --with-cc=gcc --with-fc=g77 --with-cx
x=g++ --with-mpi=0 --with-x=0 --with-clanguage=cxx --with-shared=1
--with-dynamic=1
Working directory:
Machine uname:
('Linux', 'frioul', '2.6.9-22.ELsmp', '#1 SMP Sat Oct 8 21:32:36 BST 2005',
'x86_64')
Python version:
2.3.4 (#1, Feb 17 2005, 21:01:10)
[GCC 3.4.3 20041212 (Red Hat 3.4.3-9.EL4)]
        Pushing language C
        Popping language C
        Pushing language FC
        Popping language FC
TEST configureExternalPackagesDir from
config.framework(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/c
onfig/BuildSystem/config/framework.py:815)
TESTING: configureExternalPackagesDir from
config.framework(config/BuildSystem/config/framework.py:815)
TEST configureLibrary from
PETSc.packages.NetCDF(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/P
ETSc/packages/NetCDF.py:10)
TESTING: configureLibrary from
PETSc.packages.NetCDF(config/PETSc/packages/NetCDF.py:10)
  Find a NetCDF installation and check if it can work with PETSc
PETSc.packages.PVODE(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/config/PE
TSc/packages/PVODE.py:10)
PETSc.packages.PVODE(config/PETSc/packages/PVODE.py:10)
  Find a PVODE installation and check if it can work with PETSc
TEST configureDebuggers from
PETSc.utilities.debuggers(/usr/local/temp/lian/Develop/latest/Solver/OpenSource/petsc-3.0.0-p3/co
nfig/PETSc/utilities/debuggers.py:22)
TESTING: configureDebuggers from
PETSc.utilities.debuggers(config/PETSc/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090310/8a729307/attachment.htm>
