petsc-users Digest, Vol 2, Issue 33
Matthew Knepley
knepley at gmail.com
Tue Mar 3 12:37:40 CST 2009
On Tue, Mar 3, 2009 at 9:17 AM, STEPHANE TCHOUANMO <tchouanm at msn.com> wrote:
> Ok Matt you're right. The SNES Solve is definitely at fault.
> But still there's something i dont understand in the log summary i get.
> Take for example the one for the unsteady heat equation right after:
> Event Count Time (sec)
> Flops/sec --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecMDot 22 1.0 5.0474e-04 1.0 5.48e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 6 0 0 0 0 6 0 0 0 548
> VecNorm 62 1.0 8.8694e-03 1.0 4.72e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 9 0 0 0 0 9 0 0 0 47
> VecScale 32 1.0 3.8212e-04 1.0 2.83e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 283
> VecCopy 81 1.0 1.1948e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecSet 88 1.0 8.4816e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY 10 1.0 1.8910e-04 1.0 3.57e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 1 0 0 0 357
> VecWAXPY 10 1.0 2.6472e-04 1.0 1.27e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 1 0 0 0 127
> VecMAXPY 32 1.0 1.0271e-03 1.0 4.14e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 9 0 0 0 0 9 0 0 0 414
> VecAssemblyBegin 40 1.0 8.7160e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd 40 1.0 7.5617e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin 39 1.0 1.5163e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize 32 1.0 3.8553e-03 1.0 6.65e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 5 0 0 0 0 5 0 0 0 67
> MatMult 22 1.0 1.5831e-02 1.0 2.16e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 72 0 0 0 0 72 0 0 0 216
> MatAssemblyBegin 30 1.0 6.5176e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd 30 1.0 1.2829e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatZeroEntries 9 1.0 1.8313e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SNESSolve 10 1.0 1.7674e+01 1.0 2.69e+05 1.0 0.0e+00 0.0e+00
> 3.0e+01 93100 0 0 0 94100 0 0 75 0
> SNESLineSearch 10 1.0 3.7443e+00 1.0 4.51e+04 1.0 0.0e+00 0.0e+00
> 1.0e+01 20 4 0 0 0 20 4 0 0 25 0
> SNESFunctionEval 20 1.0 7.2693e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+01 38 0 0 0 0 39 0 0 0 50 0
> SNESJacobianEval 10 1.0 1.0367e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+01 55 0 0 0 0 55 0 0 0 25 0
> KSPGMRESOrthog 22 1.0 1.4277e-03 1.0 3.88e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 12 0 0 0 0 12 0 0 0 388
> KSPSetup 10 1.0 1.3128e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve 10 1.0 2.8431e-02 1.0 1.57e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 94 0 0 0 0 94 0 0 0 157
> PCSetUp 10 1.0 2.5831e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply 32 1.0 5.7973e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Index Set 40 40 548800 0
> Vec 167 153 4198932 0
> Vec Scatter 40 40 0 0
> Matrix 1 0 0 0
> SNES 10 9 1116 0
> Krylov Solver 10 9 151920 0
> Preconditioner 10 9 0 0
> Viewer 1 0 0 0
> Now it says SNESSolve takes 93% of the main stage, right?
> In that case what does is mean the 20% for SNESLinesearch, 38% for
> SNESFunctionEval and 55% for SNESJacobianEval? It cant be percentages of the
> main stage or of the SNESSolve. Do you have an idea?
1) There is not strict separation or nesting for events. For instance, line
search, function eval, and Jacobian eval all happen inside SNESolve. In
addition,
function evaluation happens inside line search.
2) However, clearly jac eval + func eval = solve roughly. Thus, nothing else
is taking any time. This is confirmed by looking at KSPSolve, which takes no
time.
3) If you say that the first step (of 10) takes most of the time, the
conclusion for me is inescapable. LibMesh is making a whole bunch of
allocation calls
during the first time step, which is very very slow. After that, it has
the memory and everything runs fine.
I suggest talking to the LibMesh developers.
Matt
> Actually to answer your question, what is long is the first Newton
> iteration in the first time step and a debugging in DDD shows it too. So
> with the log summary i get, its obviously due to SNESSolve with Residual and
> Jacobian evaluations.
> Here is a part of my Jacobian and Residual computation routine in LibMesh
> for the basic Laplacian (- \Delta u = f ). Its called 'compute_jacobian'
> and 'compute_residual' respectively. Could you please look at it quickly and
> tell me if you see at first look something strange?
> * void compute_jacobian (const NumericVector<Number>& soln,
> SparseMatrix<Number>& jacobian)
> EquationSystems &es = *_equation_system;
> const MeshBase& mesh = es.get_mesh();
> NonlinearImplicitSystem& system =
> es.get_system<NonlinearImplicitSystem>("dc");
> const DofMap& dof_map = system.get_dof_map();
> // Define the finite volume
> FV fv;
> MeshBase::const_element_iterator el =
> mesh.active_local_elements_begin();
> const MeshBase::const_element_iterator end_el =
> mesh.active_local_elements_end();
> // The loop on every simplex
> for ( ; el != end_el; ++el)
> const Elem* elem = *el;
> dof_map.dof_indices (elem, dof_indices);
> fv.reinit(elem);
> n_dofs = dof_indices.size(); // = 4 for a hex
> Ke.resize (n_dofs, n_dofs);
> // Assemble the elementary matrix for the Laplacian problem (size
> 4*4)
> Ke=fv.elmmat(perm);
> dof_map.constrain_element_matrix (Ke, dof_indices);
> // Adds the small matrix Ke to the Jacobian
> jacobian.add_matrix (Ke, dof_indices);
> void compute_residual (const NumericVector<Number>& soln,
> NumericVector<Number>& residual)
> FV fv;
> residual.zero();
> ** // The loop on every simplex**
> fv.reinit(elem);
> n_dofs = dof_indices.size(); **// = 4 for a hex**
> Se.resize (n_dofs);
> // Compute the solution from the previous Newton iterate
> for (unsigned int l=0; l<n_dofs; l++)
> Se(l) = soln(dof_indices[l]);
> Re.resize (n_dofs);
> elmMat=fv.elmmat(perm);
> for (unsigned int i=0; i<n_dofs; i++)
> vol=fv.elmvolume(i);
> xyz=elem->point(i);
> Re(i) = vol*(xyz(0)-0.5) ;
> for (unsigned int j=0; j<n_dofs; j++)
> Re(i) += elmMat(i,j)*Se(j) ;
> dof_map.constrain_element_vector (Re, dof_indices);
> residual.add_vector (Re, dof_indices);
> and thats it!
> What amazes me is that i always get the right solution after resolution.
> Thanks a lot.
> Stephane
> Date: Tue, 3 Mar 2009 08:15:15 -0600
> Subject: Re: petsc-users Digest, Vol 2, Issue 33
> From: knepley at gmail.com
> To: petsc-users at mcs.anl.gov
> CC: tchouanm at msn.com
> On Tue, Mar 3, 2009 at 7:54 AM, STEPHANE TCHOUANMO <tchouanm at msn.com>wrote:
> Hi all,
> thank you Barry for the indication you gave me.
> As a matter of fact, i verified my jacobian and function evaluation again
> and again but i really dont see anything wrong in it.
> So i came back to the basic Laplacian problem (- \Delta u = f ) in the unit
> cube discretized in regular hexes. The numerical scheme i use is a
> vertex-centred finite volume scheme.
> The solution i get is correct compared to the exact solution (of second
> order) and i know my jacobian and residual evalutions are correct. But here
> is the log out i get.
> VecMDot 71 1.0 2.9587e-02 1.0 6.23e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 25 0 0 0 0 25 0 0 0 623
> VecNorm 77 1.0 3.3638e-02 1.0 4.24e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 42
> VecScale 74 1.0 2.1052e-03 1.0 3.26e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 1 0 0 0 326
> VecCopy 80 1.0 3.4863e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet 9 1.0 2.0776e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY 5 1.0 2.3208e-04 1.0 3.99e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 399
> VecWAXPY 1 1.0 6.6995e-05 1.0 1.38e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 138
> VecMAXPY 74 1.0 3.8138e-02 1.0 5.18e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 27 0 0 0 0 27 0 0 0 518
> VecAssemblyBegin 4 1.0 9.8636e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd 4 1.0 6.9494e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin 3 1.0 3.0706e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize 74 1.0 3.4648e-02 1.0 5.88e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 3 0 0 0 0 3 0 0 0 59
> MatMult 73 1.0 1.4618e-01 1.0 2.22e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 45 0 0 0 0 45 0 0 0 222
> MatAssemblyBegin 2 1.0 6.9899e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd 2 1.0 6.1999e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SNESSolve 1 1.0 6.7333e+01 1.0 1.08e+06 1.0 0.0e+00 0.0e+00
> 3.0e+00 99100 0 0100 99100 0 0100 1
> SNESLineSearch 1 1.0 5.1989e-01 1.0 8.91e+04 1.0 0.0e+00 0.0e+00
> 1.0e+00 1 0 0 0 33 1 0 0 0 33 0
> SNESFunctionEval 2 1.0 1.0441e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00 2 0 0 0 67 2 0 0 0 67 0
> SNESJacobianEval 1 1.0 6.6026e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 97 0 0 0 33 97 0 0 0 33 0
> KSPGMRESOrthog 71 1.0 6.5884e-02 1.0 5.60e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 51 0 0 0 0 51 0 0 0 560
> KSPSetup 1 1.0 2.2203e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve 1 1.0 2.6036e-01 1.0 2.80e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0100 0 0 0 0100 0 0 0 280
> PCSetUp 1 1.0 7.9495e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply 74 1.0 3.6445e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Index Set 3 3 111792 0
> Vec 44 3 223596 0
> Vec Scatter 3 3 0 0
> Matrix 1 0 0 0
> SNES 1 0 0 0
> Krylov Solver 1 0 0 0
> Preconditioner 1 0 0 0
> Viewer 2 0 0 0
> Draw 1 0 0 0
> Average time to get PetscTime(): 1.60268e-06
> This shows that the Jacobian evaluation takes 97% of time and the residual
> just 2% in the SNESSolve. But if you look at the total MFlops, you can see
> that its null(i guess very low) for these phases. What seems to be long is
> the part in red concerning Vector manips. You can even see at the end that
> the most memory use is in Index set and Vec.
> This analysis does not make sense. If you add all the time spent in the Vec
> operations (in red), it is less than 1/100 of the time in the
> SNES Solve. There is obviously a problem in that routine, if there is
> indeed a problem. Do you have a model of the computation that
> says that this time is too long?
> Matt
> experiments lead.
> -- Norbert Wiener
> Get news, entertainment and everything you care about at Live.com. Check
> it out! <http://www.live.com/getstarted.aspx>
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090303/7437dbba/attachment-0001.htm>
