petsc-users Digest, Vol 2, Issue 33
Matthew Knepley
knepley at gmail.com
Tue Mar 3 08:15:15 CST 2009
On Tue, Mar 3, 2009 at 7:54 AM, STEPHANE TCHOUANMO <tchouanm at msn.com> wrote:
> Hi all,
> thank you Barry for the indication you gave me.
> As a matter of fact, i verified my jacobian and function evaluation again
> and again but i really dont see anything wrong in it.
> So i came back to the basic Laplacian problem (- \Delta u = f ) in the unit
> cube discretized in regular hexes. The numerical scheme i use is a
> vertex-centred finite volume scheme.
> The solution i get is correct compared to the exact solution (of second
> order) and i know my jacobian and residual evalutions are correct. But here
> is the log out i get.
> Event Count Time (sec)
> Flops/sec --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> VecMDot 71 1.0 2.9587e-02 1.0 6.23e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 25 0 0 0 0 25 0 0 0 623
> VecNorm 77 1.0 3.3638e-02 1.0 4.24e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 2 0 0 0 0 2 0 0 0 42
> VecScale 74 1.0 2.1052e-03 1.0 3.26e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 1 0 0 0 326
> VecCopy 80 1.0 3.4863e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> VecSet 9 1.0 2.0776e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY 5 1.0 2.3208e-04 1.0 3.99e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 399
> VecWAXPY 1 1.0 6.6995e-05 1.0 1.38e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 138
> VecMAXPY 74 1.0 3.8138e-02 1.0 5.18e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 27 0 0 0 0 27 0 0 0 518
> VecAssemblyBegin 4 1.0 9.8636e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAssemblyEnd 4 1.0 6.9494e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin 3 1.0 3.0706e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> VecNormalize 74 1.0 3.4648e-02 1.0 5.88e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 3 0 0 0 0 3 0 0 0 59
> MatMult 73 1.0 1.4618e-01 1.0 2.22e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 45 0 0 0 0 45 0 0 0 222
> MatAssemblyBegin 2 1.0 6.9899e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> MatAssemblyEnd 2 1.0 6.1999e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> SNESSolve 1 1.0 6.7333e+01 1.0 1.08e+06 1.0 0.0e+00 0.0e+00
> 3.0e+00 99100 0 0100 99100 0 0100 1
> SNESLineSearch 1 1.0 5.1989e-01 1.0 8.91e+04 1.0 0.0e+00 0.0e+00
> 1.0e+00 1 0 0 0 33 1 0 0 0 33 0
> SNESFunctionEval 2 1.0 1.0441e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 2.0e+00 2 0 0 0 67 2 0 0 0 67 0
> SNESJacobianEval 1 1.0 6.6026e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 97 0 0 0 33 97 0 0 0 33 0
> KSPGMRESOrthog 71 1.0 6.5884e-02 1.0 5.60e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 51 0 0 0 0 51 0 0 0 560
> KSPSetup 1 1.0 2.2203e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> KSPSolve 1 1.0 2.6036e-01 1.0 2.80e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0100 0 0 0 0100 0 0 0 280
> PCSetUp 1 1.0 7.9495e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> PCApply 74 1.0 3.6445e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Index Set 3 3 111792 0
> Vec 44 3 223596 0
> Vec Scatter 3 3 0 0
> Matrix 1 0 0 0
> SNES 1 0 0 0
> Krylov Solver 1 0 0 0
> Preconditioner 1 0 0 0
> Viewer 2 0 0 0
> Draw 1 0 0 0
> Average time to get PetscTime(): 1.60268e-06
> This shows that the Jacobian evaluation takes 97% of time and the residual
> just 2% in the SNESSolve. But if you look at the total MFlops, you can see
> that its null(i guess very low) for these phases. What seems to be long is
> the part in red concerning Vector manips. You can even see at the end that
> the most memory use is in Index set and Vec.
This analysis does not make sense. If you add all the time spent in the Vec
operations (in red), it is less than 1/100 of the time in the
SNES Solve. There is obviously a problem in that routine, if there is indeed
a problem. Do you have a model of the computation that
says that this time is too long?
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090303/71ecdee5/attachment.htm>
