Smoother settings for AMG
BAYRAKTAR Harun Harun.BAYRAKTAR at 3ds.com
Thu Jul 30 06:28:35 CDT 2009
I always see a jump going from sequential to parallel runs with ML for all types of problems I have tried (structural mechanics, incompressible flow). But once parallel the iteration counts stay roughly constant given I use a true parallel smoother like Chebychev. My experience is that the iteration count jump is somewhere between 1.5-2.0X.
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Lisandro Dalcin
Sent: Wednesday, July 29, 2009 6:40 PM
To: PETSc users list
Subject: Re: Smoother settings for AMG
On Wed, Jul 29, 2009 at 6:48 PM, BAYRAKTAR Harun<Harun.BAYRAKTAR at 3ds.com> wrote:
> For a uniform mesh I see 20 iterations or so.
That's around the iteration count I would expect for for ML on uniform
meshes... Do this iteration count stays at about 20 when you run in 4
CPU's while still using an uniform mesh?
> [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
> Sent: Wednesday, July 29, 2009 5:23 PM
> On Wed, Jul 29, 2009 at 4:17 PM, BAYRAKTAR Harun <Harun.BAYRAKTAR at 3ds.com>
> wrote:
> Matt,
> It is from the pressure poisson equation for incompressible navier-stokes so
> it is elliptic. Also on 1 cpu, I am able to solve it with reason able
> iteration count (i.e., 43 to 1.e-5 true res norm rel tolerance). It is the
> parallel runs that really concern me.
> Actually, it was the 43 that really concerned me. In my experience, an MG
> that is doing what it is supposed
> to on Poisson takes < 10 iterations. However, if your grid is pretty
> distorted, maybe it can get this bad.
>   Matt
> Thanks,
> Harun
> Sent: Wednesday, July 29, 2009 5:00 PM
> On Wed, Jul 29, 2009 at 3:54 PM, BAYRAKTAR Harun <Harun.BAYRAKTAR at 3ds.com>
> wrote:
> Hi,
> I am trying to solve a system of equations and I am having difficulty
> picking the right smoothers for AMG (using ML as pc_type) in PETSc for
> parallel execution. First here is what happens in terms of CG (ksp_type)
> iteration counts (both columns use block jacobi):
> Are you sure you have an elliptic system? These iteration counts are
> extremely
> high.
>   Matt
> cpus    |       AMG w/ ICC(0) x1        |       AMG w/ SOR x4
> 1       |               43              |               243
> 4       |               699             |               379
> x1 or x4 means 1 or 4 iterations of smoother application at each AMG
> level (all details from ksp view for the 4 cpu run are below). The main
> observation is that on 1 cpu, AMG w/ ICC(0) is a clear winner but falls
> apart in parallel. SOR on the other hand experiences a 1.5X increase in
> iteration count which is totally expected from the quality of coarsening
> ML delivers in parallel.
> I basically would like to find a way (if possible) to have the number of
> iterations in parallel stay with 1-2X of 1 cpu iteration count for the
> AMG w/ ICC case. Is there a way to achieve this?
> Thanks,
> Harun
> AMG w/ ICC(0) x1 ksp_view
> KSP Object:
>  type: cg
>  maximum iterations=10000
>  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>  left preconditioning
> PC Object:
>  type: ml
>    MG: type is MULTIPLICATIVE, levels=3 cycles=v, pre-smooths=1,
> post-smooths=1
>  Coarse gride solver -- level 0 -------------------------------
>    KSP Object:(mg_coarse_)
>      type: preonly
>      maximum iterations=1, initial guess is zero
>    PC Object:(mg_coarse_)
>      type: redundant
>        Redundant preconditioner: First (color=0) of 4 PCs follows
>      KSP Object:(mg_coarse_redundant_)
>        type: preonly
>        maximum iterations=10000, initial guess is zero
>      PC Object:(mg_coarse_redundant_)
>        type: lu
>          LU: out-of-place factorization
>            matrix ordering: nd
>          LU: tolerance for zero pivot 1e-12
>          LU: factor fill ratio needed 2.17227
>               Factored matrix follows
>              Matrix Object:
>                type=seqaij, rows=283, cols=283
>                total: nonzeros=21651, allocated nonzeros=21651
>                  using I-node routines: found 186 nodes, limit used is
> 5
>        linear system matrix = precond matrix:
>        Matrix Object:
>          total: nonzeros=9967, allocated nonzeros=14150
>            not using I-node routines
>      Matrix Object:
>        type=mpiaij, rows=283, cols=283
>        total: nonzeros=9967, allocated nonzeros=9967
>          not using I-node (on process 0) routines
>  Down solver (pre-smoother) on level 1 -------------------------------
>    KSP Object:(mg_levels_1_)
>      type: richardson
>        Richardson: damping factor=0.9
>    PC Object:(mg_levels_1_)
>      type: bjacobi
>        block Jacobi: number of blocks = 4
>        Local solve is same for all blocks, in the following KSP and PC
> objects:
>      KSP Object:(mg_levels_1_sub_)
>        type: preonly
>      PC Object:(mg_levels_1_sub_)
>        type: icc
>          ICC: 0 levels of fill
>          ICC: factor fill ratio allocated 1
>          ICC: using Manteuffel shift
>          ICC: factor fill ratio needed 0.514899
>              Matrix Object:
>                type=seqsbaij, rows=2813, cols=2813
>                total: nonzeros=48609, allocated nonzeros=48609
>                    block size is 1
>        Matrix Object:
>          type=seqaij, rows=2813, cols=2813
>          total: nonzeros=94405, allocated nonzeros=94405
>      Matrix Object:
>        type=mpiaij, rows=10654, cols=10654
>        total: nonzeros=376634, allocated nonzeros=376634
>  Up solver (post-smoother) on level 1 -------------------------------
>      type: richardson
>      type: bjacobi
> objects:
>        type: preonly
>        type: icc
>              Matrix Object:
>                    block size is 1
>        Matrix Object:
>      Matrix Object:
>  Down solver (pre-smoother) on level 2 -------------------------------
>    KSP Object:(mg_levels_2_)
>      type: richardson
>    PC Object:(mg_levels_2_)
>      type: bjacobi
> objects:
>      KSP Object:(mg_levels_2_sub_)
>        type: preonly
>      PC Object:(mg_levels_2_sub_)
>        type: icc
>          ICC: factor fill ratio needed 0.519045
>              Matrix Object:
>                type=seqsbaij, rows=101164, cols=101164
>                total: nonzeros=1378558, allocated nonzeros=1378558
>                    block size is 1
>        Matrix Object:
>          type=seqaij, rows=101164, cols=101164
>          total: nonzeros=2655952, allocated nonzeros=5159364
>      Matrix Object:
>        type=mpiaij, rows=411866, cols=411866
>        total: nonzeros=10941434, allocated nonzeros=42010332
>  Up solver (post-smoother) on level 2 -------------------------------
>      type: richardson
>      type: bjacobi
> objects:
>        type: preonly
>        type: icc
>              Matrix Object:
>                    block size is 1
>        Matrix Object:
>      Matrix Object:
>  Matrix Object:
> AMG w/ SOR x4 ksp_view
> KSP Object:
>  type: cg
> PC Object:
>  type: ml
> post-smooths=1
>      type: preonly
>      type: redundant
>        type: preonly
>        type: lu
>            matrix ordering: nd
>              Matrix Object:
> 5
>        Matrix Object:
>      Matrix Object:
>      type: richardson
>        Richardson: damping factor=1
>      maximum iterations=4, initial guess is zero
>      type: sor
>        SOR: type = local_symmetric, iterations = 1, omega = 1
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>  Matrix Object:
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
> lead.
> -- Norbert Wiener
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
