Smoother settings for AMG
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Jul 29 16:05:19 CDT 2009
   Can you save the matrix and right hand side with the option -
ksp_view_binary and send the file "output" to petsc-maint at mcs.anl.gov
(not this email).
    Barry
If it is too big to email you can ftp it to info.mcs.anl.gov
(anonymous login) and put it in the directory incoming then send us
email petsc-maint at mcs.anl.gov with the filename.
On Jul 29, 2009, at 3:54 PM, BAYRAKTAR Harun wrote:
> Hi,
> I am trying to solve a system of equations and I am having difficulty
> picking the right smoothers for AMG (using ML as pc_type) in PETSc for
> parallel execution. First here is what happens in terms of CG
> (ksp_type)
> iteration counts (both columns use block jacobi):
> cpus	|	AMG w/ ICC(0) x1	|	AMG w/ SOR x4
> 1	|		43		|		243
> 4	|		699		|		379
> x1 or x4 means 1 or 4 iterations of smoother application at each AMG
> level (all details from ksp view for the 4 cpu run are below). The
> main
> observation is that on 1 cpu, AMG w/ ICC(0) is a clear winner but
> falls
> apart in parallel. SOR on the other hand experiences a 1.5X increase
> in
> iteration count which is totally expected from the quality of
> coarsening
> ML delivers in parallel.
> I basically would like to find a way (if possible) to have the
> number of
> iterations in parallel stay with 1-2X of 1 cpu iteration count for the
> AMG w/ ICC case. Is there a way to achieve this?
> Thanks,
> Harun
> AMG w/ ICC(0) x1 ksp_view
> KSP Object:
>  type: cg
>  maximum iterations=10000
>  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>  left preconditioning
> PC Object:
>  type: ml
>    MG: type is MULTIPLICATIVE, levels=3 cycles=v, pre-smooths=1,
> post-smooths=1
>  Coarse gride solver -- level 0 -------------------------------
>    KSP Object:(mg_coarse_)
>      type: preonly
>      maximum iterations=1, initial guess is zero
>    PC Object:(mg_coarse_)
>      type: redundant
>        Redundant preconditioner: First (color=0) of 4 PCs follows
>      KSP Object:(mg_coarse_redundant_)
>        type: preonly
>        maximum iterations=10000, initial guess is zero
>      PC Object:(mg_coarse_redundant_)
>        type: lu
>          LU: out-of-place factorization
>            matrix ordering: nd
>          LU: tolerance for zero pivot 1e-12
>          LU: factor fill ratio needed 2.17227
>               Factored matrix follows
>              Matrix Object:
>                type=seqaij, rows=283, cols=283
>                total: nonzeros=21651, allocated nonzeros=21651
>                  using I-node routines: found 186 nodes, limit used is
> 5
>        linear system matrix = precond matrix:
>        Matrix Object:
>          total: nonzeros=9967, allocated nonzeros=14150
>            not using I-node routines
>      Matrix Object:
>        type=mpiaij, rows=283, cols=283
>        total: nonzeros=9967, allocated nonzeros=9967
>          not using I-node (on process 0) routines
>  Down solver (pre-smoother) on level 1 -------------------------------
>    KSP Object:(mg_levels_1_)
>      type: richardson
>        Richardson: damping factor=0.9
>    PC Object:(mg_levels_1_)
>      type: bjacobi
>        block Jacobi: number of blocks = 4
>        Local solve is same for all blocks, in the following KSP and PC
> objects:
>      KSP Object:(mg_levels_1_sub_)
>        type: preonly
>      PC Object:(mg_levels_1_sub_)
>        type: icc
>          ICC: 0 levels of fill
>          ICC: factor fill ratio allocated 1
>          ICC: using Manteuffel shift
>          ICC: factor fill ratio needed 0.514899
>              Matrix Object:
>                type=seqsbaij, rows=2813, cols=2813
>                total: nonzeros=48609, allocated nonzeros=48609
>                    block size is 1
>        Matrix Object:
>          type=seqaij, rows=2813, cols=2813
>          total: nonzeros=94405, allocated nonzeros=94405
>      Matrix Object:
>        type=mpiaij, rows=10654, cols=10654
>        total: nonzeros=376634, allocated nonzeros=376634
>  Up solver (post-smoother) on level 1 -------------------------------
>      type: richardson
>      type: bjacobi
> objects:
>        type: preonly
>        type: icc
>              Matrix Object:
>                    block size is 1
>        Matrix Object:
>      Matrix Object:
>  Down solver (pre-smoother) on level 2 -------------------------------
>    KSP Object:(mg_levels_2_)
>      type: richardson
>    PC Object:(mg_levels_2_)
>      type: bjacobi
> objects:
>      KSP Object:(mg_levels_2_sub_)
>        type: preonly
>      PC Object:(mg_levels_2_sub_)
>        type: icc
>          ICC: factor fill ratio needed 0.519045
>              Matrix Object:
>                type=seqsbaij, rows=101164, cols=101164
>                total: nonzeros=1378558, allocated nonzeros=1378558
>                    block size is 1
>        Matrix Object:
>          type=seqaij, rows=101164, cols=101164
>          total: nonzeros=2655952, allocated nonzeros=5159364
>      Matrix Object:
>        type=mpiaij, rows=411866, cols=411866
>        total: nonzeros=10941434, allocated nonzeros=42010332
>  Up solver (post-smoother) on level 2 -------------------------------
>      type: richardson
>      type: bjacobi
> objects:
>        type: preonly
>        type: icc
>              Matrix Object:
>                    block size is 1
>        Matrix Object:
>      Matrix Object:
>  Matrix Object:
> AMG w/ SOR x4 ksp_view
> KSP Object:
>  type: cg
> PC Object:
>  type: ml
> post-smooths=1
>      type: preonly
>      type: redundant
>        type: preonly
>        type: lu
>            matrix ordering: nd
>              Matrix Object:
> 5
>        Matrix Object:
>      Matrix Object:
>      type: richardson
>        Richardson: damping factor=1
>      maximum iterations=4, initial guess is zero
>      type: sor
>        SOR: type = local_symmetric, iterations = 1, omega = 1
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>      type: richardson
>      type: sor
>      Matrix Object:
>  Matrix Object:
