SNES Convergence test
Wed Jul 22 08:42:50 CDT 2009
On Wed, Jul 22, 2009 at 8:26 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   After SNESSolve() you should call SNESGetConvergedReason() and see if the
> value is negative.
>   Use -snes_monitor and -snes_converged_reason to see why SNES is ending.
Also, -snes_view will print the tolerances it actually used.
  Matt
>   Barry
> On Jul 22, 2009, at 6:28 AM, Michel Cancelliere wrote:
>  Hi there,
>> I am having problems with the SNES,  it seems that changing atol or rtol
>> have no effect on the numbers of Newton Iterations. Do you think that it can
>> be a problem of settings in snes solver or maybe a problem on the routines
>> for Jacobian matrix evaluation? The linear solver do converge at each
>> nonlinear iterations.
>> My Code
>>  ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
>>  /*    Creation of the matrix and vector data structures*/
>>  ierr = VecCreate(PETSC_COMM_WORLD,&x); CHKERRQ(ierr);
>>  ierr = VecSetSizes(x,PETSC_DECIDE,2*input.grid.N); CHKERRQ(ierr);
>>  ierr = VecSetFromOptions(x); CHKERRQ(ierr);
>>  ierr = VecDuplicate(x,&R);CHKERRQ(ierr);
>>   ierr = MatCreate(PETSC_COMM_WORLD,&J);CHKERRQ(ierr);
>>  ierr =
>> MatSetSizes(J,PETSC_DECIDE,PETSC_DECIDE,2*input.grid.N,2*input.grid.N);CHKERRQ(ierr);
>>  ierr = MatSetFromOptions(J);CHKERRQ(ierr);
>>  ///Set function evaluation routine and vector
>>   // Assign global variable which is used in the static wrapper function
>>  pt2Object  = (void*) &system;
>>  pt2Object2 = (void*) &system;
>>  ierr =
>> SNESSetFunction(snes,R,CSystem::Wrapper_to_FormFunction,&input);CHKERRQ(ierr);
>>  // Set Jacobian matrix structure and Jacobian evaluation routine
>>  ierr =
>> SNESSetJacobian(snes,J,J,CSystem::Wrapper_to_FormJacobian,&input);CHKERRQ(ierr);
>>  /**      Customizr non linear solver; set runtime options       ***/
>> /* Set linear solver defaults for this problem. By extracting the KSP,and
>> PC contexts from
>> the SNES context, we can then directly call any KSP and PC routines to set
>> various options*/
>>  ierr = SNESGetKSP(snes,&ksp);CHKERRQ(ierr);
>>  ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>>  ierr = PCSetType(pc,PCILU);CHKERRQ(ierr);
>>  ierr =
>> KSPSetTolerances(ksp,1.e-10,PETSC_DEFAULT,PETSC_DEFAULT,30);CHKERRQ(ierr);
>>  ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>    Set SNES/KSP/PC rountime options, e.g.,
>>    -snes_view -snes_monitor -ksp_type <ksp> -pc_type <pc>
>>    These options will override thos specified above as lon as
>> SNESSetFromOptoons is called _after_ any other customization routines.
>>  ierr =SNESSetTolerances(snes,1e-100,1e-8,1e-1000,100,1000);CHKERRQ(ierr);
>>   No matter what I put here I am getting the same results (Residual Norm and
>> number of iterations)
>>  ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
>>            Evaluate initial guess; then solve nonlinear system
>>  ierr = CSystem::Cells2Vec(x,input);CHKERRQ(ierr);
>>  for (int i=0;i<system.delta_t_V.size();i++){// for (int i=0;i<700;i++)
>>      system.delta_t = system.delta_t_V[i];
>>      system.t         = system.t_V[i];
>>      input.t = system.t;
>>      input.delta_t = system.delta_t;
>>     /*\\\\\\\\\\\\\\Boundary conditions\\\\\\\\\\\\\\\\*/
>>      Rate_tot = input.F_boundary(input.t,input.delta_t);
>>      input.bc.F(input.interfaces,Rate_tot);
>>      ierr = SNESSolve(snes,PETSC_NULL,x);CHKERRQ(ierr);
>>      gauge.push_back(input.cells[0].water.p);
>>  ierr = VecDestroy(x);CHKERRQ(ierr);
>>  ierr = VecDestroy(R);CHKERRQ(ierr);
>>  ierr = MatDestroy(J);CHKERRQ(ierr);
>>  ierr = SNESDestroy(snes);CHKERRQ(ierr);
>>  ierr = PetscFinalize();CHKERRQ(ierr);
>>  return 0;
>> Output:
>> SNES Object:
>>  type: ls
>>    line search variant: SNESLineSearchCubic
>>    alpha=0.0001, maxstep=1e+008, minlambda=1e-012
>>  maximum iterations=20, maximum function evaluations=1000
>>  tolerances: relative=1e-008, absolute=1e-100, solution=0
>>  total number of linear solver iterations=2
>>  total number of function evaluations=13
>>  KSP Object:
>>    type: gmres
>>      GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>      GMRES: happy breakdown tolerance 1e-030
>>    maximum iterations=30, initial guess is zero
>>    tolerances:  relative=1e-010, absolute=1e-050, divergence=10000
>>    left preconditioning
>>  PC Object:
>>    type: ilu
>>      ILU: 0 levels of fill
>>      ILU: factor fill ratio allocated 1
>>      ILU: tolerance for zero pivot 1e-012
>>      ILU: using diagonal shift to prevent zero pivot
>>      ILU: using diagonal shift on blocks to prevent zero pivot
>>           out-of-place factorization
>>           matrix ordering: natural
>>      ILU: factor fill ratio needed 0
>>           Factored matrix follows
>>          Matrix Object:
>>            type=seqbaij, rows=64, cols=64
>>            package used to perform factorization: petsc
>>            total: nonzeros=376, allocated nonzeros=920
>>                block size is 1
>>    linear system matrix = precond matrix:
>>    Matrix Object:
>>          block size is 1
>> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r
>> -fCourier9' to print this document            ***
>> ---------------------------------------------- PETSc Performance Summary:
>> ex2.exe on a cygwin-c- named IDROCP03 with 1 processor, by Administrator
>> Wed Jul 22 13:25:47 2009
>> Using Petsc Release Version 3.0.0, Patch 6, Fri Jun  5 13:31:12 CDT 2009
>>                         Max       Max/Min        Avg      Total
>> Time (sec):           4.667e-001      1.00000   4.667e-001
>> Objects:              2.800e+001      1.00000   2.800e+001
>> Flops:                1.417e+004      1.00000   1.417e+004  1.417e+004
>> Flops/sec:            3.037e+004      1.00000   3.037e+004  3.037e+004
>> Memory:               9.325e+004      1.00000              9.325e+004
>> MPI Messages:         0.000e+000      0.00000   0.000e+000  0.000e+000
>> MPI Message Lengths:  0.000e+000      0.00000   0.000e+000  0.000e+000
>> MPI Reductions:       0.000e+000      0.00000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>>                            e.g., VecAXPY() for real vectors of length N
>> --> 2N flops
>>                            and VecAXPY() for complex vectors of length N
>> --> 8N flops
>> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>>                        Avg     %Total     Avg     %Total   counts   %Total
>>  0:      Main Stage: 4.6669e-001 100.0%  1.4174e+004 100.0%  0.000e+000
>> 0.0%  0.000e+000        0.0%  0.000e+000   0.0%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>>   Count: number of times phase was executed
>>   Time and Flops: Max - maximum over all processors
>>                   Ratio - ratio of maximum to minimum over all processors
>>   Mess: number of messages sent
>>   Avg. len: average message length
>>   Reduct: number of global reductions
>>   Global: entire computation
>>   Stage: stages of a computation. Set stages with PetscLogStagePush() and
>> PetscLogStagePop().
>>      %T - percent time in this phase         %F - percent flops in this
>> phase
>>      %M - percent messages in this phase     %L - percent message lengths
>> in this phase
>>      %R - percent reductions in this phase
>>   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over
>> all processors)
>>      #                          WARNING!!!                    #
>>      #   This code was compiled with a debugging option,      #
>>      #   To get timing results run config/configure.py        #
>>      #   using --with-debugging=no, the performance will      #
>>      #   be generally two or three times faster.              #
>> Event                Count      Time (sec)     Flops
>>       --- Global ---  --- Stage ---   Total
>>                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
>> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
>> --- Event Stage 0: Main Stage
>> SNESSolve              1 1.0 2.7082e-001 1.0 1.42e+004 1.0 0.0e+000
>> 0.0e+000 0.0e+000 58100  0  0  0  58100  0  0  0     0
>> SNESLineSearch         2 1.0 2.9807e-002 1.0 4.94e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  6 35  0  0  0   6 35  0  0  0     0
>> SNESFunctionEval      13 1.0 3.2095e-002 1.0 0.00e+000 0.0 0.0e+000
>> 0.0e+000 0.0e+000  7  0  0  0  0   7  0  0  0  0     0
>> SNESJacobianEval       2 1.0 2.5123e-003 1.0 0.00e+000 0.0 0.0e+000
>> 0.0e+000 0.0e+000  1  0  0  0  0   1  0  0  0  0     0
>> VecView                2 1.0 2.3364e-001 1.0 0.00e+000 0.0 0.0e+000
>> 0.0e+000 0.0e+000 50  0  0  0  0  50  0  0  0  0     0
>> VecDot                 2 1.0 1.2292e-005 1.0 2.54e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    21
>> VecMDot                2 1.0 1.0337e-005 1.0 2.54e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    25
>> VecNorm               20 1.0 1.1873e-004 1.0 2.54e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 18  0  0  0   0 18  0  0  0    21
>> VecScale               4 1.0 1.7321e-005 1.0 2.56e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    15
>> VecCopy                6 1.0 2.6819e-005 1.0 0.00e+000 0.0 0.0e+000
>> 0.0e+000 0.0e+000  0  0  0  0  0   0  0  0  0  0     0
>> VecSet                 5 1.0 1.9835e-005 1.0 0.00e+000 0.0 0.0e+000
>> VecAXPY                2 1.0 1.0337e-005 1.0 2.56e+002 1.0 0.0e+000
>> VecWAXPY              12 1.0 5.2521e-005 1.0 1.41e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 10  0  0  0   0 10  0  0  0    27
>> VecMAXPY               4 1.0 1.7321e-005 1.0 5.12e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  4  0  0  0   0  4  0  0  0    30
>> VecAssemblyBegin      13 1.0 3.4641e-005 1.0 0.00e+000 0.0 0.0e+000
>> VecAssemblyEnd        13 1.0 3.1848e-005 1.0 0.00e+000 0.0 0.0e+000
>> VecReduceArith         2 1.0 1.7321e-005 1.0 2.54e+002 1.0 0.0e+000
>> VecReduceComm          1 1.0 3.0730e-006 1.0 0.00e+000 0.0 0.0e+000
>> VecNormalize           4 1.0 8.4368e-005 1.0 7.64e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  5  0  0  0   0  5  0  0  0     9
>> MatMult                4 1.0 4.4978e-005 1.0 2.75e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    61
>> MatMultTranspose       1 1.0 2.3467e-005 1.0 7.52e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  5  0  0  0   0  5  0  0  0    32
>> MatSolve               4 1.0 5.6711e-005 1.0 2.75e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    49
>> MatLUFactorNum         2 1.0 7.7943e-005 1.0 2.06e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 15  0  0  0   0 15  0  0  0    26
>> MatILUFactorSym        2 1.0 1.9975e-004 1.0 0.00e+000 0.0 0.0e+000
>> MatAssemblyBegin       2 1.0 6.7048e-006 1.0 0.00e+000 0.0 0.0e+000
>> MatAssemblyEnd         2 1.0 4.1346e-005 1.0 0.00e+000 0.0 0.0e+000
>> MatGetRowIJ            2 1.0 1.0895e-005 1.0 0.00e+000 0.0 0.0e+000
>> MatGetOrdering         2 1.0 2.0254e-004 1.0 0.00e+000 0.0 0.0e+000
>> MatView                2 1.0 5.7549e-004 1.0 0.00e+000 0.0 0.0e+000
>> KSPGMRESOrthog         2 1.0 5.6152e-005 1.0 5.10e+002 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0  4  0  0  0   0  4  0  0  0     9
>> KSPSetup               2 1.0 1.5170e-004 1.0 0.00e+000 0.0 0.0e+000
>> KSPSolve               2 1.0 1.8486e-003 1.0 7.97e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 56  0  0  0   0 56  0  0  0     4
>> PCSetUp                2 1.0 1.2032e-003 1.0 2.06e+003 1.0 0.0e+000
>> PCApply                4 1.0 8.7441e-005 1.0 2.75e+003 1.0 0.0e+000
>> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    31
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions   Memory  Descendants' Mem.
>>                SNES     1              1        668     0
>>                 Vec    11             11      13596     0
>>              Matrix     3              3       7820     0
>>       Krylov Solver     1              1      17392     0
>>      Preconditioner     1              1        500     0
>>              Viewer     2              2        680     0
>>                Draw     1              1        444     0
>>                Axis     1              1        308     0
>>          Line Graph     1              1       1908     0
>>           Index Set     6              6       3360     0
>> Average time to get PetscTime(): 2.03937e-006
>> #PETSc Option Table entries:
>> -log_summary
>> -mat_type baij
>> -snes_max_it 20
>> -snes_monitor_residual
>> -snes_view
>> #End o PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4
>> sizeof(PetscScalar) 8
>> Configure run at: Mon Jul  6 16:28:41 2009
>> Configure options: --with-cc="win32fe cl --nodetect"
>> --download-c-blas-lapack=1 --with-fc=0 --with-mpi=0 --useThreads=0
>> --with-shared=0
>> Libraries compiled on Mon Jul  6 16:39:57     2009 on Idrocp03
>> Machine characteristics: CYGWIN_NT-5.1 Idrocp03 1.5.25(0.156/4/2)
>> 2008-06-12 19:34 i686 Cygwin
>> Using PETSc directory: /home/Administrator/petsc
>> Using PETSc arch: cygwin-c-debug
>> Using C compiler: /home/Administrator/petsc/bin/win32fe/win32fe cl
>> --nodetect -MT -wd4996 -Z7
>> Using Fortran compiler:
>> Using include paths: -I/home/Administrator/petsc/cygwin-c-debug/include
>> -I/home/Administrator/petsc/include
>> -I/home/Administrator/petsc/include/mpiuni
>> Using C linker: /home/Administrator/petsc/bin/win32fe/win32fe cl
>> Using Fortran linker:
>> Using libraries: -L/home/Administrator/petsc/cygwin-c-debug/lib
>> -L/home/Administrator/petsc/cygwin-c-debug/lib -lpetscts -lpetscsnes
>> -lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc
>>  -L/home/Administrator/petsc/cygwin-c-debug/lib -lf2clapack -lf2cblas
>> -lmpiuni Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
>> Thank you in advance for your help,
>> Michel Cancelliere
>> Politecnico di Torino
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090722/10691c0f/attachment-0001.htm>
