SNES Convergence test
Wed Jul 22 08:26:39 CDT 2009
    After SNESSolve() you should call SNESGetConvergedReason() and see
if the value is negative.
    Use -snes_monitor and -snes_converged_reason to see why SNES is
ending.
    Barry
On Jul 22, 2009, at 6:28 AM, Michel Cancelliere wrote:
> Hi there,
> I am having problems with the SNES,  it seems that changing atol or
> rtol have no effect on the numbers of Newton Iterations. Do you
> think that it can be a problem of settings in snes solver or maybe a
> problem on the routines for Jacobian matrix evaluation? The linear
> solver do converge at each nonlinear iterations.
> My Code
>  ierr = SNESCreate(PETSC_COMM_WORLD,&snes);CHKERRQ(ierr);
>   /*    Creation of the matrix and vector data structures*/
>   ierr = VecCreate(PETSC_COMM_WORLD,&x); CHKERRQ(ierr);
>   ierr = VecSetSizes(x,PETSC_DECIDE,2*input.grid.N); CHKERRQ(ierr);
>   ierr = VecSetFromOptions(x); CHKERRQ(ierr);
>   ierr = VecDuplicate(x,&R);CHKERRQ(ierr);
>    ierr = MatCreate(PETSC_COMM_WORLD,&J);CHKERRQ(ierr);
>   ierr = MatSetSizes(J,PETSC_DECIDE,PETSC_DECIDE,2*input.grid.N,
> 2*input.grid.N);CHKERRQ(ierr);
>   ierr = MatSetFromOptions(J);CHKERRQ(ierr);
>   ///Set function evaluation routine and vector
>    // Assign global variable which is used in the static wrapper
> function
>   pt2Object  = (void*) &system;
>   pt2Object2 = (void*) &system;
>   ierr =
> SNESSetFunction
> (snes,R,CSystem::Wrapper_to_FormFunction,&input);CHKERRQ(ierr);
>   // Set Jacobian matrix structure and Jacobian evaluation routine
>   ierr =
> SNESSetJacobian
> (snes,J,J,CSystem::Wrapper_to_FormJacobian,&input);CHKERRQ(ierr);
>  /**      Customizr non linear solver; set runtime options       ***/
> /* Set linear solver defaults for this problem. By extracting the
> KSP,and PC contexts from
> the SNES context, we can then directly call any KSP and PC routines
> to set various options*/
>   ierr = SNESGetKSP(snes,&ksp);CHKERRQ(ierr);
>   ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>   ierr = PCSetType(pc,PCILU);CHKERRQ(ierr);
>   ierr = KSPSetTolerances(ksp,1.e-10,PETSC_DEFAULT,PETSC_DEFAULT,
> 30);CHKERRQ(ierr);
>   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>     Set SNES/KSP/PC rountime options, e.g.,
>     -snes_view -snes_monitor -ksp_type <ksp> -pc_type <pc>
>     These options will override thos specified above as lon as
> SNESSetFromOptoons is called _after_ any other customization routines.
>   ierr =SNESSetTolerances(snes,
> 1e-100,1e-8,1e-1000,100,1000);CHKERRQ(ierr);   No matter what I put
> here I am getting the same results (Residual Norm and number of
> iterations)
>   ierr = SNESSetFromOptions(snes);CHKERRQ(ierr);
>             Evaluate initial guess; then solve nonlinear system
>   ierr = CSystem::Cells2Vec(x,input);CHKERRQ(ierr);
>  for (int i=0;i<system.delta_t_V.size();i++){// for (int i=0;i<700;i+
>       system.delta_t = system.delta_t_V[i];
>       system.t         = system.t_V[i];
>       input.t = system.t;
>       input.delta_t = system.delta_t;
>      /*\\\\\\\\\\\\\\Boundary conditions\\\\\\\\\\\\\\\\*/
>       Rate_tot = input.F_boundary(input.t,input.delta_t);
>       input.bc.F(input.interfaces,Rate_tot);
>       ierr = SNESSolve(snes,PETSC_NULL,x);CHKERRQ(ierr);
>       gauge.push_back(input.cells[0].water.p);
>  ierr = VecDestroy(x);CHKERRQ(ierr);
>  ierr = VecDestroy(R);CHKERRQ(ierr);
>  ierr = MatDestroy(J);CHKERRQ(ierr);
>  ierr = SNESDestroy(snes);CHKERRQ(ierr);
>   ierr = PetscFinalize();CHKERRQ(ierr);
>   return 0;
> Output:
> SNES Object:
>   type: ls
>     line search variant: SNESLineSearchCubic
>     alpha=0.0001, maxstep=1e+008, minlambda=1e-012
>   maximum iterations=20, maximum function evaluations=1000
>   tolerances: relative=1e-008, absolute=1e-100, solution=0
>   total number of linear solver iterations=2
>   total number of function evaluations=13
>   KSP Object:
>     type: gmres
>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-030
>     maximum iterations=30, initial guess is zero
>     tolerances:  relative=1e-010, absolute=1e-050, divergence=10000
>     left preconditioning
>   PC Object:
>     type: ilu
>       ILU: 0 levels of fill
>       ILU: factor fill ratio allocated 1
>       ILU: tolerance for zero pivot 1e-012
>       ILU: using diagonal shift to prevent zero pivot
>       ILU: using diagonal shift on blocks to prevent zero pivot
>            out-of-place factorization
>            matrix ordering: natural
>       ILU: factor fill ratio needed 0
>            Factored matrix follows
>           Matrix Object:
>             type=seqbaij, rows=64, cols=64
>             package used to perform factorization: petsc
>             total: nonzeros=376, allocated nonzeros=920
>                 block size is 1
>     linear system matrix = precond matrix:
>     Matrix Object:
>           block size is 1
> ***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -
> r -fCourier9' to print this document            ***
> ---------------------------------------------- PETSc Performance
> Summary: ----------------------------------------------
> ex2.exe on a cygwin-c- named IDROCP03 with 1 processor, by
> Administrator Wed Jul 22 13:25:47 2009
> Using Petsc Release Version 3.0.0, Patch 6, Fri Jun  5 13:31:12 CDT
> 2009
>                          Max       Max/Min        Avg      Total
> Time (sec):           4.667e-001      1.00000   4.667e-001
> Objects:              2.800e+001      1.00000   2.800e+001
> Flops:                1.417e+004      1.00000   1.417e+004  1.417e+004
> Flops/sec:            3.037e+004      1.00000   3.037e+004  3.037e+004
> Memory:               9.325e+004      1.00000              9.325e+004
> MPI Messages:         0.000e+000      0.00000   0.000e+000  0.000e+000
> MPI Message Lengths:  0.000e+000      0.00000   0.000e+000  0.000e+000
> MPI Reductions:       0.000e+000      0.00000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of
> length N --> 2N flops
>                             and VecAXPY() for complex vectors of
> length N --> 8N flops
> Summary of Stages:   ----- Time ------  ----- Flops -----  ---
> Messages ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 4.6669e-001 100.0%  1.4174e+004 100.0%  0.000e
> +000   0.0%  0.000e+000        0.0%  0.000e+000   0.0%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flops: Max - maximum over all processors
>                    Ratio - ratio of maximum to minimum over all
> processors
>    Mess: number of messages sent
>    Avg. len: average message length
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with
> PetscLogStagePush() and PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flops in
> this phase
>       %M - percent messages in this phase     %L - percent message
> lengths in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max
> time over all processors)
>       #                          WARNING!!!                    #
>       #   This code was compiled with a debugging option,      #
>       #   To get timing results run config/configure.py        #
>       #   using --with-debugging=no, the performance will      #
>       #   be generally two or three times faster.              #
> Event                Count      Time (sec)
> Flops                             --- Global ---  --- Stage ---
> Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
> len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> SNESSolve              1 1.0 2.7082e-001 1.0 1.42e+004 1.0 0.0e+000
> 0.0e+000 0.0e+000 58100  0  0  0  58100  0  0  0     0
> SNESLineSearch         2 1.0 2.9807e-002 1.0 4.94e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  6 35  0  0  0   6 35  0  0  0     0
> SNESFunctionEval      13 1.0 3.2095e-002 1.0 0.00e+000 0.0 0.0e+000
> 0.0e+000 0.0e+000  7  0  0  0  0   7  0  0  0  0     0
> SNESJacobianEval       2 1.0 2.5123e-003 1.0 0.00e+000 0.0 0.0e+000
> 0.0e+000 0.0e+000  1  0  0  0  0   1  0  0  0  0     0
> VecView                2 1.0 2.3364e-001 1.0 0.00e+000 0.0 0.0e+000
> 0.0e+000 0.0e+000 50  0  0  0  0  50  0  0  0  0     0
> VecDot                 2 1.0 1.2292e-005 1.0 2.54e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    21
> VecMDot                2 1.0 1.0337e-005 1.0 2.54e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    25
> VecNorm               20 1.0 1.1873e-004 1.0 2.54e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 18  0  0  0   0 18  0  0  0    21
> VecScale               4 1.0 1.7321e-005 1.0 2.56e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  2  0  0  0   0  2  0  0  0    15
> VecCopy                6 1.0 2.6819e-005 1.0 0.00e+000 0.0 0.0e+000
> 0.0e+000 0.0e+000  0  0  0  0  0   0  0  0  0  0     0
> VecSet                 5 1.0 1.9835e-005 1.0 0.00e+000 0.0 0.0e+000
> VecAXPY                2 1.0 1.0337e-005 1.0 2.56e+002 1.0 0.0e+000
> VecWAXPY              12 1.0 5.2521e-005 1.0 1.41e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 10  0  0  0   0 10  0  0  0    27
> VecMAXPY               4 1.0 1.7321e-005 1.0 5.12e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  4  0  0  0   0  4  0  0  0    30
> VecAssemblyBegin      13 1.0 3.4641e-005 1.0 0.00e+000 0.0 0.0e+000
> VecAssemblyEnd        13 1.0 3.1848e-005 1.0 0.00e+000 0.0 0.0e+000
> VecReduceArith         2 1.0 1.7321e-005 1.0 2.54e+002 1.0 0.0e+000
> VecReduceComm          1 1.0 3.0730e-006 1.0 0.00e+000 0.0 0.0e+000
> VecNormalize           4 1.0 8.4368e-005 1.0 7.64e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  5  0  0  0   0  5  0  0  0     9
> MatMult                4 1.0 4.4978e-005 1.0 2.75e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    61
> MatMultTranspose       1 1.0 2.3467e-005 1.0 7.52e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  5  0  0  0   0  5  0  0  0    32
> MatSolve               4 1.0 5.6711e-005 1.0 2.75e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    49
> MatLUFactorNum         2 1.0 7.7943e-005 1.0 2.06e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 15  0  0  0   0 15  0  0  0    26
> MatILUFactorSym        2 1.0 1.9975e-004 1.0 0.00e+000 0.0 0.0e+000
> MatAssemblyBegin       2 1.0 6.7048e-006 1.0 0.00e+000 0.0 0.0e+000
> MatAssemblyEnd         2 1.0 4.1346e-005 1.0 0.00e+000 0.0 0.0e+000
> MatGetRowIJ            2 1.0 1.0895e-005 1.0 0.00e+000 0.0 0.0e+000
> MatGetOrdering         2 1.0 2.0254e-004 1.0 0.00e+000 0.0 0.0e+000
> MatView                2 1.0 5.7549e-004 1.0 0.00e+000 0.0 0.0e+000
> KSPGMRESOrthog         2 1.0 5.6152e-005 1.0 5.10e+002 1.0 0.0e+000
> 0.0e+000 0.0e+000  0  4  0  0  0   0  4  0  0  0     9
> KSPSetup               2 1.0 1.5170e-004 1.0 0.00e+000 0.0 0.0e+000
> KSPSolve               2 1.0 1.8486e-003 1.0 7.97e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 56  0  0  0   0 56  0  0  0     4
> PCSetUp                2 1.0 1.2032e-003 1.0 2.06e+003 1.0 0.0e+000
> PCApply                4 1.0 8.7441e-005 1.0 2.75e+003 1.0 0.0e+000
> 0.0e+000 0.0e+000  0 19  0  0  0   0 19  0  0  0    31
> Memory usage is given in bytes:
> Object Type          Creations   Destructions   Memory  Descendants'
> Mem.
>                 SNES     1              1        668     0
>                  Vec    11             11      13596     0
>               Matrix     3              3       7820     0
>        Krylov Solver     1              1      17392     0
>       Preconditioner     1              1        500     0
>               Viewer     2              2        680     0
>                 Draw     1              1        444     0
>                 Axis     1              1        308     0
>           Line Graph     1              1       1908     0
>            Index Set     6              6       3360     0
> Average time to get PetscTime(): 2.03937e-006
> #PETSc Option Table entries:
> -log_summary
> -mat_type baij
> -snes_max_it 20
> -snes_monitor_residual
> -snes_view
> #End o PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 4 sizeof(void*) 4
> sizeof(PetscScalar) 8
> Configure run at: Mon Jul  6 16:28:41 2009
> Configure options: --with-cc="win32fe cl --nodetect" --download-c-
> blas-lapack=1 --with-fc=0 --with-mpi=0 --useThreads=0 --with-shared=0
> Libraries compiled on Mon Jul  6 16:39:57     2009 on Idrocp03
> Machine characteristics: CYGWIN_NT-5.1 Idrocp03 1.5.25(0.156/4/2)
> 2008-06-12 19:34 i686 Cygwin
> Using PETSc directory: /home/Administrator/petsc
> Using PETSc arch: cygwin-c-debug
> Using C compiler: /home/Administrator/petsc/bin/win32fe/win32fe cl --
> nodetect -MT -wd4996 -Z7
> Using Fortran compiler:
> Using include paths: -I/home/Administrator/petsc/cygwin-c-debug/
> include -I/home/Administrator/petsc/include -I/home/Administrator/
> petsc/include/mpiuni
> Using C linker: /home/Administrator/petsc/bin/win32fe/win32fe cl --
> Using Fortran linker:
> Using libraries: -L/home/Administrator/petsc/cygwin-c-debug/lib -L/
> home/Administrator/petsc/cygwin-c-debug/lib -lpetscts -lpetscsnes -
> lpetscksp -lpetscdm -lpetscmat -lpetscvec -lpetsc        -L/home/
> Administrator/petsc/cygwin-c-debug/lib -lf2clapack -lf2cblas -
> lmpiuni Gdi32.lib User32.lib Advapi32.lib Kernel32.lib Ws2_32.lib
> Thank you in advance for your help,
> Michel Cancelliere
> Politecnico di Torino
