Petsc And Slepc, singular system
Matthew Knepley
knepley at gmail.com
Tue Jul 21 16:24:30 CDT 2009
On Tue, Jul 21, 2009 at 4:09 PM, Umut Tabak <u.tabak at tudelft.nl> wrote:
> On Tue, Jul 21, 2009 at 03:56:11PM -0500, Matthew Knepley wrote:
> > If your system is badly scaled, roundoff errors could result in a pivot
> > larger than our tolerance. It is also possible that your preconditioner
> > resulted in a badly scaled system.
> > Matt
> Hi,
> Thanks for the fast reply.
> since the system is singular condition number will be bad any way,
> but I was wondering if there were already ways to overcome this
> problem. And are there ways to prevent the preconditioner to give a
> badly scaled system, what I mean is that the system is singular so
> will preconditioning improve that? I definitely read about these.
Well, the default is ILU which can do horrendously things. Try running with
Jacobi as a test. It should fail like you want. In my opinion, blackbox PCs
almost never work, and what you really need is something tailored to your
problem (which is linear algebra heresy).
Matt
> Thanks and best,
> Umut
> Quote: You can not teach a man anything, you can only help him find it
> within himself.
> Source: Galileo Galilei
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090721/03946660/attachment.htm>
